how do i tell if they are xenons?
andrewl74 Aug 7, 2007
  1. andrewl74
    andrewl74 New Member
    23
    got a a4 3.0 cabriolet, how do i know if the lights are xenons? - may be a daft question but they look abit yellow to me!
    thanks
  2. bubstar
    bubstar Member
    550
    Is there a height adjuster on the headlamp switch? If so they're standard.
  3. andrewl74
    23
    i'll have a look thanks, next question, can i just put xenon lights in to replace the standard ones?
  4. bubstar
    bubstar Member
    550
    You'll need a proper conversion kit but they aren't strictly legal without autoleveling and washers.
    Plenty have them mind, and still get MOT's ok.
    BUB
  5. andrewl74
    23
    thanks for your help!
  6. batwad
    batwad Member
    864
    Look straight in them. If you go blind they're xenons.
  7. golf
    golf ***** rent boy VCDS Map User
    1,556
    If you had xenons you'd know you have them. It's not difficult to tell the two apart.
  8. batwad
    batwad Member
    864
    Unless you're blind.
    Maybe the OP has looked directly at them and gone blind, hence why he doesn't know if they're xenons or not. Mind you, that does raise the question of how he's managed to post on the forum. Has he got a Braille monitor?
  9. andrewl74
    23
    it reads to me... i've had the car a week and not been out in the dark!!!
  10. golf
    1,556
    If you have headlamp washers, then it's more than likely that you have Xenons. Xenons ignite when they come on, this is because they need 20,000 volts to actually start up, if you switch your lights on and they flash, and then slowly blend in to a white colour from blue then you have xenons.
    Hope this answers your question.
