HOW DO I TAKE OFF DOOR CARD???
S3-Chris Jun 13, 2008
  1. S3-Chris
    S3-Chris If its not broke....break it!!
    303
    61
    DRIVERS WINDOW CHUCKED IT YESTERDAY - NOT SURE WHAT IT COULD BE, NEED TO TAKE OFF THE DOOR CARD TO CHECK IT OUT, WHATS THE BEST WAY WITHOUT BREAKING CLIPS ETC????
    THANKS
  2. Shy19s
    Shy19s Oil running through my veins.
    886
    Driver side -
    Couple of screws, top left, top right, possibly a few on the bottom, i cant remember, and then you have to take the piece of plasic that is under the door handle out, i think its held in by a screw also, and there is a screw under that that you need to un-do.. once you've done all that (if my memory serves me right) all you have to do is go to the bottom left hand corner and pull upwards in a diagonal fashion, and it should pop off. undo the connections at the window and speaker terminals.
    Please correct me if ive missed anything it was a while since i took them them off.
  3. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    If you want the Audi Manual for the A3 interior go to http://myweb.tiscali.co.uk/macnee/home.htm and download the manual (24MB). On section 70 it has exploded diagrams and the like to help out on removing dorr cards/trims/handles etc.
    Also what do you mean 'the window chucked it'?
  4. Shy19s
    886
    Jester.. you make me laugh in some of your posts like out loud lollol... I think he ment the motor blew. lol.
  5. AndyMac
    9,832
    46
    HOW DO I TAKE THE CAPS LOCK OFF!
  6. 1animal1
    9,978
    press all of the keys once lol
  7. jojo
    28,908
    3,564
    Ctrl+Alt+Del a few times usually works.
  8. S3-Chris
    303
    61
    The motor isnt broke as i can still hear it trying to work, luckily the window is in the up position, its just as if maybe a swith had died or something....
  9. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    so have you finally took the door card off?
  10. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    its going to be the regulator so common on vag cars
  11. S3-Chris
    303
    61
    fixed already, the motor had just frozen, unplugged it all and started it all up again and it worked a treat!
    btw - it has been the easiest door card iv took on and off! pi$$ case!
