How do i remove the inner plastics/carpet from my avant boot lid
gtvlew Apr 22, 2013
  1. gtvlew
    gtvlew Member
    67
    As above folks, i am worried i will snap the plastic surround , how does the carpet lower section come off aswell ,cheers Gary
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    With great difficulty! It's all one piece if I remember correctly but keep tugging and the clips should give.
  3. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    618
    21
    There are 4 screws to start with, 2 visible and two inside the triangle holder iirc.
    Undo those, then the carpet part should be hanging a little. After that, it's a case of un-popping a few of the metal clips holding it to the bootlid. Eventually, it will be hanging from the back, at which point trial and error with a little force to unhook it
  4. gtvlew
    gtvlew Member
    67
    thank you :yahoo:
  5. Ian-83
    Ian-83 Member
    202
    To give you a heads up at the edge next to the screen at each corner is two little clips which are a pain . All there are is where the lower trim hooks over the upper trim. Try to lightly hook them away and the trim should come off ok.
  6. quattrojames
    14,050
    574
    The best advice is to pull firmly, but gently (?) AS CLOSE to the clip as possible.
  7. RobMorris
    RobMorris Member
    539
    10
    Nice one im just about to attempt this myself.
  8. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    the clips are metal so don't be scared of breaking them, just good sharp tug ;)
  9. quattrojames
    14,050
    574
    The clips are metal yes, but they only slot into an open plastic slot on the plastic cover, and it doesn't take much to break that.
  10. Greeny233
    1,094
    385
    That's what super glue was invented for ;)
  11. T0m
    T0m Active Member
    516
    26
    I second all that is said above it is a biatch as I had to replace my wiper motor and you need to give it a good old pull, try and get your hands in there and prise it by the clips the toughest part is the bit along the rear window its a bugger to get off, then trying to align them up when putting it back all I can say is thank gawd for the screws.
