How do I know if I've got a factory alarm fitted?
Keeno Mar 10, 2010
  1. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    Firstly, I know it sounds like a completely obvious question, but bear with me!
    I've got the LED's next to the door pins and the button at the bottom of the door pillar to turn the internal sensors on/off.
    However! Being unsure I got the mrs to lock the door from the outside with me inside and pulled the handle - no alarm.
    Now having an unnatural (and unexplained) hatred of car electrics, can someone point me in the direction of where I might find the alarm siren etc and therefore evidence of whether the alarm is fitted and up the swany or just non-existent.
    Thanks muchly!
  2. <tuffty/>
    21,680
    4,107
    did you wait at least 30 seconds before opening the door?
    AFAIK, most if not all A3's came with a factory alarm and immobiliser :)
  3. Keeno
    701
    I honestly can't remeber! I've definatly got an immobilser, so it would stand to reason that I'd have an alarm as well. I'll have to give it another bash and then possibly crack out the Haynes manual...
  4. Nilz
    11,361
    899
    Why dont you put the windows down, leave it for about 60 seconds, the leds will flash rapidly until it is set, then they will flash every second or two, once they start flashing like this it means it is set, then all you need to do is put your arms in the car and wave them like you just dont care, this should set the alarm off, if you dont hear anything however and your indicators start flashing, it means you do have an alarm, its just that the siren will be buggered (as they are cr4p and are probably as loud as a casio watch alarm).
    Hope that helps.
  5. Keeno
    701
    It does indeedy! Just for reference, where abouts is the siren located?
  6. Nilz
    11,361
    899
    Its in the boot, in the rear arch, under the sub, hidden in a deep dark corner.
  7. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i saw 2 horn type things in the passenger side bit of the bumper/wheel arch thing when fitting my CAI. One of the those the alarm maybe?
  8. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    I have this problem and have been meaning to fix it.
    I bet that is a proper b*stard to get to as well!! :(
    EDIT: Obviously, as you don't want thieves ripping it out....
  9. <tuffty/>
    21,680
    4,107
    Narp... just horns :)
  10. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    That's your horn fella, the two parts created a multi tone horn noise.
  11. Keeno
    701
    Haha! Unlucky!
    Oh, wait...
  12. Lemon S3
    Lemon S3 Alex
    1,390
    41
    My siren is fecked as well, hazards flash but no noise. Or its a slient alarm so the ''robber'' doesnt know the alarm is going off so will be caught in the act :detective2: lol
  13. Keeno
    701
    Well, I've concluded my alarm is shafted. No blinky lights when it sets, which I would assume means it hasn't actually set at all. Definatly doens't go off when waving my arm through an open window...
    Balls.
  14. Nilz
    11,361
    899
    Thats odd Keeno, im sure they all came with alarms as starndard, have you got any vent looking things on the pillars as thats where the ultrasonics are to sense movement.
  15. sportstractor
    sportstractor Chugger
    2,709
    hmmm have you vagcomed the car, if the microswiches in the locks have gone the alarm will not set, vagcom will say if they are playing up.
  16. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    nilz18t has it bob-on right with a good method to test interior monitoring when your alarm is arming, and sportstractor's above is a common reason for them not arming.
    If you do get access to VAG-COM/VCDS to scan for issues with the microswitches, you can also run 'Output Tests' on Module 35 (Central Locking) - as part of this your alarm is triggered, so you'll get a better idea of whether it's working at all or not, then it's a process of elimination to find out where things are falling down...
    Regards,
    Rob.
  17. Keeno
    701
    Yeah, I've got the the trimmings for having an alarm fitted. LED's on the door pins, small vent type jobbies in my B-pillars, the button for turning off interior sensors...
    Next stop is VAGCOM then. I can see this becoming a bit of a headache...
