How do I fix the rubbing caused when lowering...
Mi11ar Sep 26, 2013
  1. Mi11ar
    Mi11ar Active Member
    316
    35
    Just fitted coil overs to my Car and I have rubbing as warned previously, I know I can higher the Car and leave it about 40mm to avoid any rubbing but is this the only solution?
  2. Morty
    Morty "StAtIk FaNtAtIk"
    Few options;
    Raise it.
    Stretch the tyres and camber.
    Smaller wheels.
    Pull and roll the arches and pop some spacers on if it inner.
  3. Grale1
    Grale1 Active Member
    795
    44
    Idiots rubbing on the driveshaft I think you can get a roll bar with bigger loops or if your coilovers have a tab on them you could use an s3/tt or cupra r roll bar then the drp link will attach to the coilovers if you have the tab.
    but I'm sure someone with a lot more experience than me will come along and correct me lol
  4. Morty
    If the driveshaft is rubbing it'll be on the chassis. You'll need a notch to go lower. Arb won't help that.
  5. Pubemammal
    Pubemammal Active Member
    530
    117
    43
    The driveshaft will be rubbing on the ARB (anti roll bar). Use an ARB from any mk1 TT to solve the problem. You can pick them up for around £30 delivered from ebay
    Mi11ar and Lavis89 like this.
  6. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,938
    768
    What he said ^ I believe white line and r32 arb's are options aswell, but expensive ones
  7. Mi11ar
    316
    35
    Thanks everyone I'll have a hunt for them on Ebay now :)
  8. Mi11ar
    316
    35
  9. Grale1
    795
    44
    Looks like the right one
