How do I fit an oil temp gauge?
Benjiman46 Feb 18, 2012
  1. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Hi all!
    How would I fit an oil temperature gauge to my S3 8L APY?
    I need to know where I would put the sensor or where I would get the reading.
    Hope you can help
    Ben
  2. jay1601
    jay1601 Well-Known Member
    1,341
    72
    put a sensor in the oil drain plug. adapter is about £5 from ebay. and just buy a external gauge for the readings
  3. Benjiman46
    551
    24
    Thanks for the reply.
    And will the oil drain plug sensor set-up be ok? I've heard mixed reviews about these.
    I've ordered the Gauge and it comes with a "Fitting Kit" so I'm guessing I'll need the sump plug with a certain thread in it that matches the kit?
  4. <tuffty/>
    21,355
    3,922
    The oil drain plugs for these sensors are quite frankly an pile of sh*te
    Stick it in the top of the oil filter housing or tee it into where the oil pressure sensor is...
    All the cars I have seen that have these things leak or have rounded the stupid brass or aluminium POS adaptor nut so you can't get them out to change the oil..
  5. jay1601
    1,341
    72
    i didn't have one problem with the sensor being in my sump. i've still got the sensor and adapter in now (taken the gauge out to fit a wideband AFR gauge instead)
    i've done 2 oil changes having the sensor didn't cause a problem (oil change every 6 months)
  6. Benjiman46
    551
    24
    Ok, mixed views there lol the kit I've bought has a 1/8 NPT threaded sensor included (which is M10 I believe) is there ANYWHERE on the engine, oil filter housing or sump where I can just bolt this straight in?
    If not, what size sump plug adaptor will I need? Is it M14 x 1.5?
    Cheers in advance! :)
  7. Benjiman46
    551
    24
    Anyone? :) I'm going to have a look tomorrow, but would love for someone to save me a job hahaCheers
  8. jay1601
    1,341
    72
    the sump plug is m14x1.5
  9. Benjiman46
    551
    24
    Nice one! Thanks very much :)
