How do i change side light bulbs??
AudiiduA Jul 24, 2010
  1. AudiiduA
    AudiiduA Member
    359
    Hi Fellas, does the headlight have to come out??
    Thanks all
  2. simon.m
    simon.m Active Member
    2,747
    it dont have to come out mate but it is tight so if you have small hands its easy
  3. paul20v
    paul20v Audi fanatic
    1,113
    Twist the headlight leveler it makes the bulb really easy to get at :)
  4. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    Yes, they can be tricky. Make sure it's not raining when you start lol, otherwise the air may be blue.
  5. ChrisFurlong
    ChrisFurlong Avantageous
    343
    I would just take the headlights out. Very easy. 4 Torx screws on each [T15 or T20 I think]. Then as paul said, twist the main beam bulb and it makes it much easier to get to them.
  6. AudiiduA
    AudiiduA Member
    359
    Cheers Fellas! will have a go!!!!!
  7. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    jsut make sure you're doing the METAL torques and not the plastic allen-key ones ;)
    quattro james has posted a lot of pics on this: drivers side is easier if you undo two screws and take off the plastic ducting: james.... pictures please!!
  8. quattrojames
    14,060
    583
    vulcan808 likes this.
  9. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    Dude, that's a great picture, thanks!
    My headlight bulb needs replacing so this helps nicely!
  10. quattrojames
    14,060
    583
    I never said that for reference.....
  11. crazy88
    4,939
    437
    I added it as I've seen you add many pictures which are helpful.
    It should be a title you can call yourself. Thanks anyway :)
  12. quattrojames
    14,060
    583
    I try to help where I can :thumbsup:
  13. hitchwest
    hitchwest Member
    33
    i bet theres alot of audis going round with side lamp bulbs out what a nightmare of a job to get i thought german engineering was good
  14. quattrojames
    14,060
    583
    Its better than on many cars though, taking the light out is a five minute job when you know how. Plenty of cars make it impossible to change a bulb, and a damn sight harder to take the lights out too!
  15. scott b
    scott b Active Member VCDS Map User
    1,254
    ie vw passat upto 56 plate, bumper off job to get the headlight out
  16. jd26
    jd26 Member
    294
    James thanks for that guide used it to just change my dipped beams :)
    One thing though which ill need for future reference. How does the connecter unclip?
    Me and the old man swapped the bulb over without undo-ing it cause there was enough room, scared to force it incase i broke the plastic.
    Ill need to know for when I order my hids so if someone can label the diagram for which way/place to bend the bugger thatd be great :p
  17. jd26
    jd26 Member
    294
    Anyone? Ill go snappin tings if I dont check haha
  18. Shane-Ireland
    Shane-Ireland Active Member Team Ibis Team V6 Audi S3 quattro Audi A4 Audi Avant Owner Group TDi
    288
    25
    Pull back the plastic tab in the center with your thumb or small falt head and then pull the whole plug off,simply really once you've done it once.
  19. quattrojames
    14,060
    583
    Its a notorious weak point in them, if the tab breaks or gets damaged they're a b*st*rd to get off. I resort to brute force to pull the plug off mine, always a worrying moment though...
