How difficult is it to replace the slam panel?
ptr Jul 28, 2011
  1. ptr
    ptr Member
    128
    I need to replace the slam/crash panel on my A3 following a small bump. Does anyone know if you have to remove the radiator and aircon rad or can they just be put to one side?
  2. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3 Manual
    193
    15
    The rads can be moved to one side quite easily.
    It's literally bolt off bolt on. Make sure you get an OEM one though as I had a non OE one and it didn't quite sit right on my old Leon.
    ptr likes this.
  3. jay1601
    jay1601 Well-Known Member
    1,347
    73
    very easy mate i did mine a couple of days ago. takes around a hour and half from start to finish
    undo the 2 spline bolts
    take off the impact bar
    4 bolts holding the rad in place
    3 bolts holding the headlights in
    swap over and replace
    easy job
    ptr likes this.
  4. ptr
    ptr Member
    128
    Cheers lads!
    I got an OEM one from a scrappy for £30, this weekend is sorted then - got a list of jobs to do on the car :)
