How difficult is it to fit front discs and pads on a B5 TDi 2.5 v6q?
Tom_B Mar 30, 2012
  1. Tom_B
    Tom_B Member
    292
    20
    I need to replace the discs and pads on my beloved A4. I can do some mechanicing but am not an expert by any means. How demanding is doing this job?
    Tom
  2. aragorn
    17,956
    701
    I'd say fairly streight forwards, so long as you have a decent socket set
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Rediculously simple.
    Only issue i have ever had was one of the caliper bolts was seized in, and sheared off when i tried to remove it. but the pads didnt look like they had EVER been changed
  4. Oranoco
    Oranoco Well-Known Member
    3,799
    349
    One of the most easy DIY jobs you can do. Budget on 2 hours all in. Should be ample to get everything out, do the job, pack up and even a sly cuppa in the middle
  5. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    done mine on my 2.4 V6 last week the passenger side was eaiser to take the carrier off.
    a tip leave one side of the old pad on the caliper so you dont damage anything and i used one of those one handed G Clamp to push the piston home. IIRC on mine the carrier bolt was 17mm. better off with 1/2 drive socket.
  6. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    Depends on how good you with are spanners/sockets I guess. Look at a Haynes manual to see how many 'Spanners' are next the task of changing the discs/pads.
    It is an easy job though.
  7. rasA4
    3,287
    119
    I think I'll need to change the brake fluid though. Don't its changed for a while.
  8. Tom_B
    Tom_B Member
    292
    20
    ... and the answer is very starightforward, got front discs and pads replaced this morning - A4 now drives much better because it stops on a sixpence. Thanks to all for help and encouragement.
