how difficult is it to change a timing belt???
audii Jun 21, 2011
  1. audii
    audii Member
    hi to all.
    im wondering how difficult it is to change a timming belt on a a4 quattro sport, and what problems and diffaculties i'm likley to encounter and how much space putting the loock carrier in the service positon will make as all the rite ups show it removed?
    any help will be graetfully recieved thank you
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,038
    785
    What engine? If you have never done one before best done with bumper removed.
  3. audii
    audii Member
    its a ajl 1.8t curiouse to know how much space there is to work in or do i really need to empty and swing the rad out of the way??
  4. B5NUT
    4,038
    785
    Not enough if you have never done one before, I have a mate who is an Audi tech, he can complete the job with the frontend in the service position, but he does them almost every day. I've done a few now and would not attempt the job with the frontend in place.
    I would also do more than just the belt, may as well do the tensioner, water pump & thermostat and all other belts.
  5. abblettm
    abblettm New Member
    15
    There is enough space but a bit tight to get a knocking stick in to knock crankshaft bolts, make sure you get Allen keys in properly
  6. audii
    audii Member
    ok thanks
  7. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    222
    Hi there,
    Had mine changed recently on my tqs, I didnt have the time to, if you search around a bit I think there is an american post that some one has done a step by step guide on how to.... I think you'll need a special tool for the belt.
    Basically you have to drop the front end off - you can't do it any other way....
    I was going to get it done by a main stealer, they do a fixed belt price of 350 inc vat with a warranty.
    I dont like the stealers around Essex and had a specialist do mine plus belts and water pumps and some other bits....
  8. Bradderz_1988
    3,995
    262
    Ye as previous posts really if you take front end off it's fairly straight forward. You can just move it out the way and rest the front crossmember on something at a comftable height did one at weekend took me about just over an hour on a non turbo. It looks dog when the front end is on but heaven when it's off lol
  9. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Theres a "How To" on AudiWorld Tech Articles
    May be slight differences for your car/engine, but should be pretty much spot on.
  10. Oranoco
    Oranoco Well-Known Member
    4,009
    414
    Not too bad at all, my biggest issue was the fact my car had teh older 112 tooth belt which has been discontinued and I then had to changeeverything to accept the 113 tooth belt. Did the timing belt, auxilery belt and fitted a new radiator in a day on my mums drive with a lunch trip to KFC
