How accurate is the A3 speedo
Steve-L Aug 3, 2006
  1. Steve-L
    Steve-L Member
    93
    As the title says, I know most speedo's read under but curious to know if anyone has tested the accuaracy at varying speeds primarily 60, 70 & 100mph ?
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,598
    3,173
    If you have a Road Angel or sat-nav, or anything with GPS functionality, you should be able to display your real speed, & compare it with the speedo. They usually update around every three seconds, so there's alway a bit of lag when accelerating, but once your speed is steady, you can compare directly. When my GPS is showing a steady 70mph, the car speedo is reading 73.
  3. Vertigo1
    Vertigo1 Well-Known Member Team Navarra Audi S3
    3,815
    891
    Speedos always over-read, never under. Mine is about 10% out, so 100mph indicated is 91 actual and 127 actual is 140 indicated.
  4. bobtooke
    bobtooke New Member
    Mine is about 5 to 6 % out from my GPS (ie at an actual 70mph shows 73/74-ish). This is about average for most modern cars.
  5. dmaudi
    dmaudi Member
    218
    my understanding is that legally speedo's have to read over, I think it is 6%, totally agree with the numbers, I've seen mine go past 160 yet my SatNav says max attained is 143 or 146, can't remember exactly from my desk,
    does that also mean the odometer reads over or is that accurate? otherwise we're all getting less miles out of our cars than we think....
    anyone know if the speed limiter's based on speedo speed or true speed?
  6. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    In mine, speedo reads 70MPH when sat-nav displays 68MPH so approx 3% over-read here.......
  7. Eeef
    Eeef Lord of War
    1,607
    mine is exactly 5% over.
  8. RobB
    RobB Member
    317
    Mine seems almost spot on at lower speeds, using those speed warning radar signs that flash your speed when you go past.
    Also, I read that the 3.2 does 24.7mph / 1,000rpm in 6th, which makes my 100mph at 4,000rpm seem pretty accurate. Same for top speed - 159mph in Germany - still creeping up slowly then a noticeable stop at about 6,300rpm, which means only about 3mph out compared to the limiter's supposed 250kph / 156mph.
  9. adamhill
    adamhill New Member
    21
    Mine is about 10% and consistent with slow and fast speeds. I am shocked by this tolerance and questioned it with Audi UK - they simply said that 10% was within their acceptable range.
    I told them that 10% tolerance is historical from the old cable driven speedos and that I do not consider it to be acceptable on a modern car where the speedo is electronic.
    We agreed to disagree in the end
  10. marriedblonde
    marriedblonde Active Member
    4,371
    I'm sure there was another thread about this not so long ago...
  11. marriedblonde
    4,371
    We do not know our car's true spped. We can get pretty close with a sat nav unit (accurate to approx 0.1%)
    There's lots of variables to consider regarding our speedo's. New compared to old worn tyres will have an effect. Under/over inflation will obviously effect the speedo reading. The theres the plethora of tyre manufacturers out there. Although the tyres same they are the same size the circumference is different from make to make.
    To give an example of the difference of a new compared to old tyre:
    If a new 225/40/18 tyre has a diameter of 637mm the circumference is 2000mm (I am using pi at 3.14 for these exmaples so not 100% accurate but will give you an idea)
    So that tyre has 8mm of tread say. When worn to the legal limit the tread will be 1.6mm so the diameter is now only 622.2mm and therefore the circumference is now 1953.7
    The difference as a % between old and new is 2% thats without taking into account for tyre inflation. So if your speedo is overreading by 10% with a new tyre it will be over reading less with a worn one.
    J.
