Hot under the bonnet
S3-Oski May 15, 2009
  1. S3-Oski
    S3-Oski Member
    484
    Hi is it normal if having driven the car hard for it be very hot under the bonnet, like where the strutbrace is to hot to touch? As thats what mine was like today, just curious as it seemed very hot, cheers OSKI
  2. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    yep the turbo lives just below the strut brace so id expect it to be really hot after a burn
  3. <tuffty/>
    20,989
    3,760
    stays hot for ages too... If you open the bonnet at night after some spirited driving, you can see the exhaust manifold glowing red hot too....
  4. S3APY
    S3APY Member
    127
    The ventilation in the front is just 50% open i have opend mine 100%...:meeting:
  5. How do you do this?
    I guess this is what heatsoak is?
  6. S3APY
    S3APY Member
    127
    its clost behind the S3 emblem. I used a power tool...
  7. Dennis Moeller
    Dennis Moeller Member
    444
    Any pic's? Did it help reduce heat and did you do it mainly to cool down intake?
  8. S3APY
    S3APY Member
    127
    yes you hit it spot on... You will see the closed thing when you stick your head inn inn daylight i think its a good thingeling to do... :) More power more heat...:tumble:
  9. Dennis Moeller
    444
    Yeah I heard a chap talked about it a couple of weeks ago, he also did it to reduce heat at the air-intake manifold. I'm fitting a FMIC soon and maybe a BMC CDA so I'm gonna tear apart the entire front anyway. WILL strip all unnessecary plastic :w00t:
  10. S3APY
    S3APY Member
    127
    we shuld talk Norwegian i live in Vest-Agder...:w00t:
  11. S3-Oski
    S3-Oski Member
    484
    Cool yeah i undertsand the turbo is just there, i could not belive the heat what was coming from the engine when i popped the bonnet, and that strutbrace was too hot to touch and took so long to cool down, i was just curious as if it was totally normal, i supose with a remap too the turbo is working harder therfore gives off more heat,
  12. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,142
    1,971
    be careful not to touch the exhaust after a run as that might be hot as well...:undwech:
  13. S3-Oski
    S3-Oski Member
    484
    Lol!, honestly i was really suprised at the heat, almost looked like a little bit of steam was coming off my turbo too? ever so slightly
  14. abdus
    abdus Top Gear VCDS Map User
    1,827
    It will be very hot, even more at this time of the year. You will really feel the heat even on the bonnet.
    And as said above, the turbo is right there underneath, so expect it to be really hot.
    I travelled about 4 miles to a friend's place when we swapped the turbo. After 5 hours, the area around the turbo was still warm...lol
  15. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    After a proper drive you can make the turbo glow red hot. So yes I'd expect it to be slighty warm.
  16. S3APY
    S3APY Member
    127
    Here is my custom ventilation...
  17. 1animal1
    9,978
    thats one clean rocker cover...........
  18. S3APY
    S3APY Member
    127
    Thanks...
  19. Dani_B19
    9,159
    359
    So what you done then. drilled two large holes behind the s3 badge?
    Has it made any difference?
    Whats the engine temp like after a run?
  20. S3APY
    S3APY Member
    127
    Yes
    Yes
    Colder
  21. voorhees
    16,142
    1,971
    good blank for the induction...how come Audi never did that?
  22. S3APY
    S3APY Member
    127
    Mr sarkastic...:laugh:
  23. Dani_B19
    9,159
    359
    Voorhees sarkastic! Noo :)
  24. bl_1969
    bl_1969 Roads? We Dont Need Roads!!!!
    358
    S3APY would should be banned from the forum! Thats just PORN pics he posted! :yum:
    Love that Engine bay! It's so clean, yet down right dirty!
    :respekt:
  25. S3APY
    S3APY Member
    127
    Thanks man :)
    I think you get a hoter enginebay with the org Audi induction patent...
    Whay...? You dont get so mutch coold air in to the hard working turbo :)
  26. S3APY
    S3APY Member
    127
    My intake temp in a pull is 8"C higher then the air temp outside. It goes from 29 to 18-20"C.
    Show me your numbers in "C...? Someone...? Its cool to see what you have
    Her is my tool... :)
    This is only crusig can not take picture stedy on a pull working with the log funchen:)
  27. S3APY
    S3APY Member
    127
    What is your air intaketemp with a hot enginebay...?
  28. S3APY
    S3APY Member
    127
    This is my last mod. There is a Water pipe under the intake house and its heating the intakeair not good. I covered it to prevent that. The pink is spot on... :) And the temp whent down 1"C...
  29. Dani_B19
    9,159
    359
    s3apy you have any more close up pictures?
    What you used to cover it with?
  30. S3APY
    S3APY Member
    127
    I will post some pictures to morro...
  31. jojo
    28,856
    3,516
    Are you German by any chance? :)
  32. S3APY
    S3APY Member
    127
    Norwegian sorry to all of you ho hate me for my spelling skills... :)
  33. Dani_B19
    9,159
    359
    luck forward to it
  34. S3APY
    S3APY Member
    127
    Same stuff as you see on the alu filtercoverplate and you need alu tape to get it perfect... **** off :)
  35. S3APY
    S3APY Member
    127
