hot start.
vw754 Apr 28, 2011
  1. vw754
    vw754 vorsprung Durch Technik
    2,334
    58
    GOLF TDI MK5 1.9 105bhp.
    Starts first time when cold/1st thing in morning,but once hot takes a good 3-5 seconds...no faults via vcds,drives spot on.
    Ive heard its starter motor but dont want buy one unless im 100% positive....anyone else and ideas/experiences?
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    Cant be the starter if it cranks OK but our 2.5Tdi does the same and we think it may be the fuel pump timing and hope it will get sorted when the belts are changed soon.My son in law has a touran with the 105bhp and his always cranks a lot when hot but again its due for a belt change
  3. vw754
    2,334
    58
    if you google hot start issue all (well 99%) say its the starter,doing a bit of research ive found out that it should spin at 270rpm,when they dont and spin slower (you cant tell how much slower until you bench test it) the ecu dont inject the fuel,aparently the solonoid gets worn.
  4. Mike B
    1,101
    40
    Thanks I will pass that on
  5. Mike B
    1,101
    40
    We have now had the cambelt service done by Chris Adams and watching him was enlightening and entertaining.He showed how the timing was out by nearly 2 cogs and he finished by fine tuning it on VAGCOM.Starting is no problem now hot or cold and problems seem to over
  6. vw754
    2,334
    58
    interesting as i have vcds (vag-com) il try figure how to check it with that just in-case
