hot air all the time even when on cold !
vw754
vorsprung Durch Technik
U.K
got these fault codes on 56 plate avant.... 00710 01809 01810 heaters are blowing hot air all the time even when set to cold !
I had this with one side of my car. I can't remember the code number but it's probably either one of the regulators has failed or the regulator arm is stuck (mine was stuck).
I only had to undo the passenger side, I removed the glovebox and there are a set of regulator motors, two with green arms and one with an orange arm. I turned the air on and when you press various combinations, the motors all move. My temperature regulator (orange arm) didn't move when I changed the temperature so it was stuck to hot. I pushed it with my finger and it worked.
If you get hot air from all vents could it be a fuse?
