hose/pipe help and info, with pics.
brys3 Aug 27, 2010
  1. brys3
    brys3 Member
    144
    hi, again. i noticed last week one of my plastic pipes had snapped clean off both ends with oil deposits around the connections. im not sure what the pipe does but the car appeared to run fine. i replaced the pipe this afternoon(pic 1), 35 quid! upon fitting i noticed, looking at the engine head on, at the bottom of the pipe there is a t piece then runs left to a plastic curved piece (pic 2, taken from my mates 20v golf) mine is not connected. it doesnt look like it has snapped off but it doesnt fit back on. could anybody enlighten me as to what this pipework does and if the disconnected pipe needs replacing or how to reattatch it. any help again will be very much appreciated.
    pic 1,
    pic 2
  2. Sandip
    2,456
    99
    Sounds like it has broke bud, change 06a 103 213 f, are all you other pipes ok under the intake manifold, they have a tendancy to split
    I changed all the parts marked with a red dot, using both oem and Forge parts
  3. brys3
    brys3 Member
    144
    Good man I'll do the same, what exactly does it all do?
  4. Sandip
    2,456
    99
    It's all to do with the crankcase breather system, it's mind boggling, some people have got rid of most of the stuff and gone for a catch can, i've opted to keep the oem set and just renew and upgrade the material of some of the hoses with these > Awesome > Forge Silicone Breather Hoses for the 225hp 1.8T
  5. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    That is one hell of a good answer Sandip. wow. :readit: :applaus: :rockwoot:
  6. brys3
    brys3 Member
    144
    So how much of it would be removed through the installation of a catch can as I was thinking if getting one anyway
  7. Sandip
    2,456
    99
    I'm not sure exactly but i know that the pcv valve goes (058 133 753 B), basically by having the catch can there will be less chance of split hoses which means less chance of losing boost. Mine's done 123k on the standard hoses and by replacing the common spliting hoses for the more superior Forge ones i think i'll be safe for quite a while:)
  8. 1animal1
    9,978
    or just check out the catch can thread and delete the whole lot ;)
  9. Sandip
    2,456
    99
  10. 1animal1
    9,978
    great minds :D
  11. danger S3
    danger S3 Member
    376
    23
    brys3, do you know the part number for the pipe you replaced in the first picture as mine is breaking?
    also what is the easiest way to get underneath the intake manifold? take it off?
  12. s3tle
    s3tle Member
    239
  13. s3tle
    s3tle Member
    239
    yon don't have to remove manifold, just the dipstick and metal plate which bolts to manifold and hold dipstick inplace, then you can reach under
  14. brys3
    brys3 Member
    144
    brilliant thanks, oil catch can looks like far too much effort
