Horrid noise when Engine returns to idle
Turbo Lag FTW Dec 17, 2007
  1. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    Hi guys, I can hear a horrible noise coming from the engine bay when the engine returns to idle from mid to high revs. Its like a rattling/chatter noise and is coming from the turbo side of the bay. Is it possibly the turbo needing a bit of attention? Its still boosting very well as the polish guys at work keep finding out when they try to race me in their volvos and vauxhall vectras and astras, they really believe the latter two cars to be really good cars but I tend to disagree.
    Anyways any help would be much appreciated. Btw the car has done 91000 miles and is reguraly serviced.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    check your heat shields, common problem sounds a lot worse than it is
  3. Broken Byzan
    13,237
    465
    Or wastegate rattle maybe.OUCH
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    What sort of rattle, a light tinny sound or a heavier solid rattle?
    Best thing to do is remove the plastic sound deadening and get someone to rev the engine and have a close inspection.
  5. Turbo Lag FTW
    235
    Ok Im gonna have to take it to audi specialist for a quick look over, The more I listen to the engine while I up the revs a little, the more it sounds like the noise is coming from under the cam cover and not from the heatshield. Im gettin pretty freaked out now, and to be honest the car is barely using oil or water, although fuel consumption has dropped 3mpg but I was just gonna put that down to the cold weather. Although i would love to rule out the turbo wastegate.
