Horn location??
RS_Cosworth Jan 4, 2010
  1. RS_Cosworth
    RS_Cosworth Member
    124
    Can anybody tell me where I can expect to find the horn on my 2003 A3 TDi Sport? It's stopped working so will have to investigate why, and it would be a great help if I could go straight to it rather than stripping god knows how many parts off just trying to find the damn thing!
  2. Scott
    Scott Well-Known Member
    1,306
    126
    See if this helps: http://i669.photobucket.com/albums/vv56/scott1andrews/Audi-A3-Horn-1.gif
  3. RS_Cosworth
    RS_Cosworth Member
    124
  4. ps44u
    ps44u Member
    57
    the link does not work, any more pics?
  5. fangio
    fangio Well-Known Member
    1,520
    182
    That's cos it's out of date! :rolleyes:
  6. ps44u
    ps44u Member
    57
    still need to know the location of the horn? anyone?
  7. RS_Cosworth
    RS_Cosworth Member
    124
    There's two mate, a low tone & a high tone and they're hidden behind the front fog light grilles :thumbsup:
  8. Ads
    Ads License to drive
    8,230
    612
  9. ps44u
    ps44u Member
    57
    Not funny, need to know the real location of the horn, the one where the sound comes from!
  10. Ads
    8,230
    612
    Good luck finding it.
  11. mike foster
    3,967
    ps44u - lighten up mate !! You won't make many friends or get much help on here with that attitude. :no:
    The two horns are still in the same place that RS_Cosworth told you in post #7 !! :yes:
  12. Ads
    8,230
    612
    Let him learn the hard way mate. :happy:
  13. ps44u
    ps44u Member
    57
    thanks for that, are there two of them? at either side? thanks for your help
  14. ps44u
    ps44u Member
    57
    Mike i have lightened up, im just so frustrated with this horn, its just not working and im trying to get to the cause of it, cheers mike
  15. ps44u
    ps44u Member
    57
    Ads wots up wiv ya, its a bit childish to dislike all of my posts, you dont understand how frustrated i am, got to many things goin on, i just want get things done yh, i know you just wanted to have a joke and a laugh ok you win haha, cos when i saw that pic i did laugh myself!
  16. mike foster
    3,967
    One at each side but you only need to check one. Both will not have become faulty at the same time.
    You have no doubt checked the fuses so it must be the wiring or the airbag switch. If you can get the car scanned easily it will tell you the problem.
    Look for somebody local to you in the 'VCDS' user section who will help.
  17. ps44u
    ps44u Member
    57
    so do i have to unclip the grill with the foglight in? or is the whole bumper coming off?
  18. Ads
    8,230
    612
    Without meaning to sound even more childish.... you started the 'disliking'.
    You say you found the pic funny so why get all menstrual about it then??
    As mike said, chill a bit, i was only pulling your leg mate, its how we roll. :friends:
  19. mike foster
    3,967
    Unclip the foglight grille and you will see the horn. If you can get under the car and remove the lower engine cover then all will become clear and it will be easier to fix.
  20. ps44u
    ps44u Member
    57
    Mike thanks for all your help, respect. ill update tomorrow when i have a look at it, its wet and dark outside now, cheers
  21. ps44u
    ps44u Member
    57
    No worries LOL!
  22. NHN
    29,551
    1,777
    LMFAO had me lol
    You have many things going on that arent anybodies fault on here, you have an issue that many people will help you with, but we also like to smile at least once every millenium, so relax, take the advice on board, report back what you've found then by process of elimination we can potentially find the issue for you.
    Exactly :)
    Anyway, you do realise Ads has tendencies, especially for Gyms.
    Back to horns, if both of them are faulty, then I atm dont think its the horns at fault unless the wiring to them have both been damaged somehow, ideally you would be best to have a scan done by someone local if there are no obvious signs of damage to the area/parts/wiring & given they're hidden behind the grills & recessed so they shouldnt get damaged by big road bumps, I'm leading towards fuse or relay.
    There is a relay for horn above drivers footwell, small rectangular on the relay plate, maybe different for your engine code/year, but worth a check for any build up or corrosion on all connection points including connectors to the horns.
  23. Ads
    8,230
    612
    This thread is so horny.
  24. ps44u
    ps44u Member
    57
    Had a look myself, could not see anything wrong with them, been to mechanic who spent a while searching for the problem, and his conclusion is that the wiring for the horns has been somehow 'disconnected', i told him thats a bit obvious, going to see an auto electrician on monday, will update then.
    and i also have a tendency for gym:yum:lol
  25. NHN
    29,551
    1,777
    Just have a go yourself, check the relays above footwell, could even remove, stick 12v across terminals to see if relays are activating ok.
    I had an issue with a steering module that always made the damn horn go of when plugged in, had to change the module which inturn fixed the horn.
