Horn Fuse keeps blowing
imported_TDi_Singh Apr 26, 2006
  1. Can anyone help me!!!! /ubbthreads/images/graemlins/noidea.gif
    My horn does not work.
    This happened a year or so ago and I found the fuse had blown so replacing this solved the problem.
    This time, the fuse has blown and replacing it with a new one only blows as soon as you press the horn.
    Any ideas???? /ubbthreads/images/graemlins/shocked.gif
    MOT coming up soon! This is a fail!
    Your help would be much appreciated.
    For info: 2000 A4 2.5 Tdi
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,702
    158
    Disconect the horn unit, replace fuse and press again...if fuse blows there would appear to be short in the wiring loom somewhere, if so, a case of tack and trace!
    If it doesn't blow, then the horn unit could be fault.
    May even be bad connections / corrosion in the connecter. Clean all contacts up.
    Dan
  3. The911SC
    The911SC Active Member
    1,032
    Dont press the horn... !..
    /ubbthreads/images/graemlins/dancing.gif
