Hope you guys can help
IOM-S3 Dec 21, 2010
  1. IOM-S3
    IOM-S3 Member
    119
    Hi Guys,
    owned my AMK s3 for around 6 months now, for a while it has been knocking fairlt loudly fron the front of the car when going over slight bumps in the road, my immediate thought was the anti roll bar bushes etc. So i bought an r32 23 mm front roll bar, bushes and a set of drop links :)
    Had them fitted, it has made the noise alot better but i can still hear a faint knocking sound, i thought this would have cured the problem :(
    is there anything else i should check peeps?
    thank you:confused:
    lee
  2. s3_stig
    s3_stig Member
    376
    Arb bushes maybe shocks are worn broken springs!
  3. IOM-S3
    IOM-S3 Member
    119
    Thanks mate, just done ARB bushes and a new roll bar and new drop links. Was set that this would fix it but seems like its still faintly knocking, not half as bad though
  4. s3_stig
    s3_stig Member
    376
    I had knocking aswell I changed what you have, but also done my wishbone bushes aswell my knocking went see if you have any play in the wishbones
  5. IOM-S3
    IOM-S3 Member
    119
    yeah i will do, might be worth my doing wishbione bushes, ball joints TR ends etc, get the filter sorted?
  6. s3_stig
    s3_stig Member
    376
    Yeah then you've pretty much have covered every thing
  7. Stanley
    Stanley Member
    201
    Top mounts. Mine are making a clunking sound at the moment, and theyre quite guilty on these.
    Jack the car up and see if you have any movement in an up-and-down motion on both front wheels. Always a good clue as to the health of the top mounts.
    Whilst its up it'd make sense to check everything else too.
  8. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    definately top mounts
  9. IOM-S3
    IOM-S3 Member
    119
    Hey guys, thanks for all the helpful replies. I jacked the car up, couldnt feel any play in the top mount area, knocking is just getting worse :( could it be anything else do you think or shall i just replace the top mounts first before i go buiying anything else?
    thanks
    lee
  10. SiGainey
    SiGainey Member
    506
    9
    It COULD be the dog bone mount if that is very worn? But my money would be on the top mounts
  11. IOM-S3
    IOM-S3 Member
    119
    just ordered some LCR top mounts and bearings guys, will let you know if it fixes the issue :)
  12. IOM-S3
    IOM-S3 Member
    119
    Hi Guys, fitted my Leon cupra r top mounts and bearings? when all tightened when the strur was off the car there was a bit of play in the top mount? is this normal?
    also it didnt fix my knocking issue, but looked at my front wishbone rear bush and they have cracks in them where they have started to seperate, could this be the culprit?
    thanks
  13. <tuffty/>
    21,688
    4,119
    I haven't done my top mounts yet so can't comment on the play but I was involved in doing a spring change on an S3 today which had std top mounts and you could waggle them a tad... I would imagine the 'play' is actually the bearings but until I do this myself then I can't be sure...
    As for your bushes while I cannot say if its causing your knoking noise they won't be helping if they are in that kinda state... do you have the voided bush in them? most S3's seem to come with those... mine did! the better ones to replace them with is the later TT ones as they are solid and work much better...
  14. metricspaces
    metricspaces Member
    661
    +1 , changed my voided ones with solid TT ones, it certainly added more feel to the steering, you could feel the movement in the front wheels more, less of the soft steering you get with standard.
  15. quattro1
    quattro1 Member
    639
    +2 on changing to solid bushes on my a3, completely changed feel of the front end!
  16. Sandip
    2,456
    99
    I'd put my money on the shocks :)
  17. IOM-S3
    IOM-S3 Member
    119
    cheers for reply ppl :) ermm not sure on the bush tbh, what do you mean ? so would you not go for the Polybush route?
    Why u think shocks sandip?
    what i have done so far,
    new roll bar and bushes
    drop links
    Top mounts and bearings
    Yeah Leon Cupra top mounts have slightly more play in them than standards buddy, also the cup that sits on top does not stick up in the engine bay like the normal s3 ones. ?
  18. quattro1
    quattro1 Member
    639
  19. IOM-S3
    IOM-S3 Member
    119
    Yeah that looks like it mate
  20. IOM-S3
    IOM-S3 Member
    119
    so wold you recommend going for powerflex?
  21. <tuffty/>
    21,688
    4,119
    Don't use powerflex for that position... they split after a short time... powerflex for the front bush in the wishbone is ok, TT solid rubber ones for the rear of the wishbone... avoid the other type in the first link as they are voided type and will flex... GSF sell the TT ones for around £10 each
  22. metricspaces
    metricspaces Member
    661
    I followed this advice too from tuffty :) . I also changed front drop links and top mounts at the same time. Made a good difference.
  23. Sandip
    2,456
    99
  24. IOM-S3
    IOM-S3 Member
    119
    thanks for the replies again :) i didnt check my shocks no mate, tbyh it knocks straight away, i am just wondering whether the top mounts that i got are making it worse?
    tufftybloke where is GSF, sorry to sound stupid lol,
    thanks alot
    Lee
  25. IOM-S3
    IOM-S3 Member
    119
    anyone got the part number for the TT solid bush at all?
  26. <tuffty/>
    21,688
    4,119
  27. IOM-S3
    IOM-S3 Member
    119
    thanks matey :)
  28. IOM-S3
    IOM-S3 Member
    119
    Just an update, i have ordered the solid TT bushes for my lower arms, fingers crossed this will fix the knocking so i can actualy spend some money buying some trick bits for it instead of fixing the blummin thing lol.
    Do the front wishbone bushes tend to go aswell?
  29. <tuffty/>
    21,688
    4,119
    If you have the later large bush then yeah, they do go as they are voided... I fitted powerflex ones in mine as this position doesn't take the hammering the rear ones do
  30. IOM-S3
    IOM-S3 Member
    119
    i have a facelift AMK bud, ahh right so its the front ones that differ in size?
  31. <tuffty/>
    21,688
    4,119
    yeah, earlier cars had smaller bushes but later ones had huge voided things with an alloy centre... if you have the earlier small bushes (solid rubber) then they should be fine but if you have the later larger bush with the void then I would be tempted to change them to the powerflex ones...
  32. IOM-S3
    IOM-S3 Member
    119
    awesome mate, thanks for that, if i have a look tonight and see which one i have, will give you an update, cheers again matey
  33. IOM-S3
    IOM-S3 Member
    119
    Does anyone know the numbers to look for on the lower arms to determine what bushes I need?
  34. IOM-S3
    IOM-S3 Member
    119
    Hi Guys, Just jacked my driver side front up to have a play about and see if i can see anything obvious to why my car is knocking. If i grab the bottom of the wheel and pull towards me there is a bit of play in it? i would of thought this would have been the balljoint, but looking at it when pulling it it doesnt seem to move but the wheel does?
    Could a wheel bearing be causing my herendous knocking?
    but it sounds like its coming from both sides and i havnt checked the other side yet.
    any help would be great lads :)
  35. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Track rod...maybe
  36. Sandip
    2,456
    99
    Still thinks it's the shocks lol
  37. IOM-S3
    IOM-S3 Member
    119
    i can see where your coming from sandip, i will jack it up tomoro again and have a good play with it. good point S3 dave i hadnt checked the track rod ends when moving the wheel?
    any other ideas, i am going to do my lower arm bushes anyway and put a new set of ball joints on just for safe measure.
  38. quattro1
    quattro1 Member
    639
    i still say wishbone bushes (rear)
    i bet when the wheel is on the ground you can move it from left to right with abit of force?
  39. IOM-S3
    IOM-S3 Member
    119
    Will try that tomorow mate , thank you. i am just worried now that its a wheel bearing, but i think i would notice some noise if it was. I suppose when pulling on the bottom of the wheel it could be moving the rear bush. The rear bush is really worn and cracked.
  40. Sandip
    2,456
    99
    My wishbone bush has been worn for nearly 2 yrs, it gets mentioned by my mot guy every year lol I'll get it done when it starts giving me issues
    If you can remove the shock and check it then it would rule it out for sure, mine had nothing left in it, i didn't get the normal symptoms of a knackered shock
