Hope somebody can help - Central Conv issues
Cruiser89 Dec 28, 2011
  1. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Hi guys,
    Hope you are all well.
    I usually post up quite a bit in the A3 but have a specific problem with a mate's 2002 Audi A4.
    This problem has been going on a while and am at a loss of what to do...
    Long story short, the back doors on this A4 dead-bolted and failed to open when unlocked. Had the Central Convenience module checked out and repaired. It had an issue with one of the chips on the board. Another ECU was then used to clone on to my mate's A4 module. Plugged the bugger back in and it worked... hooorah. All doors unlocked and did everything it didn't before.
    All was fine, then the car was doing weird stuff. Indicators wouldn't flash on lock or unlock, interior lock button didn't work, when a door was open the DIS would show the opposite door as open, interior lights wouldn't come on when opened.
    Sooooo, I thought enough was enough and got another ECU from a breakers yard on the cheap. Plugged in and ensured all the coding was correct and thought all was good. However the car will not let me re-code any new keys (It's as if the car forgot it has the remote function) Passenger door won't unlock. It does however flash, correct DIS display and unlock with the interior lock button.
    Also another strange thing is that the DIS displays Brake warning when the car has started... This is new.
    So to eliminate some problems, I changed the battery in both remotes and still it wouldn't recode the keys. Even tried wiping the ECU to forget its previous keys. I also plugged the old ECU back in and the car will still not code any keys.
    Below is a VCDS scan... If anybody can offer any advice or help that would be great :)
    Im usually pretty good with coding and know quite a bit about the ECUs etc, but gotta admit, i need help with this one.
    Wednesday,28,December,2011,13:33:35:33777
    VCDS Version: Release 11.11.0
    Data version: 20111111
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN:<<EDIT>> Mileage: 232130km/144238miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 CG
    Component: 1,9l R4 EDC 0000SG 1366
    Coding: 00002
    Shop #: WSC 63351
    VCID: 5EB87965DA2C8AE
    WAUZZZ8EZ1A043208 AUZ6Z0A0035187
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front D620
    Coding: 04255
    Shop #: WSC 06315
    VCID: E5CAD6897F7A596
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0406
    Coding: 00000
    Shop #: WSC 63351
    VCID: DEB8F9655A2C0AE
    1 Fault Found:
    00710 - Defroster Flap Positioning Motor (V107)
    41-00 - Blocked or No Voltage
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279
    Component: int. Lastmodul RDW 0510
    Coding: 00001
    Shop #: WSC 63351
    VCID: EFE6B4A1AD86936
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0011602
    Shop #: WSC 63351 000 00000
    VCID: F4ECBBCD94A0B0E
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0302
    Coding: 00001
    Shop #: WSC 63351
    VCID: 3668C1C5125C62E
    3 Faults Found:
    01333 - Door Control Module; Rear Left (J388)
    49-10 - No Communications - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    01330 - Central Control Module for Central Convenience (J393)
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 C
    Component: KOMBI+WEGFAHRS. RB4 D11
    Coding: 00400
    Shop #: WSC 00272
    VCID: 29521AB9D3E23D6
    4 Faults Found:
    01304 - Radio
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0503
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDEA0B1999E6F6
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgerát TBF 1310
    Coding: 23279
    Shop #: WSC 63351
    VCID: 74EC3BCD44A030E
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 4.11
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 4.11
    7 Faults Found:
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01561 - Left Rear Door
    59-00 - Can't Unlock
    61-00 - Won't De-Safe
    01331 - Door Control Module; Driver Side (J386)
    62-10 - No or Incorrect Adjustment - Intermittent
    01559 - Drivers Door
    60-10 - Won't Safe - Intermittent
    01560 - Passenger Door
    01332 - Door Control Module; Passenger Side (J387)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186
    Component: concert II GRO 0001
    Coding: 00001
    Shop #: WSC 63351
    VCID: E4CCCB8D744020E
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    36-00 - Open Circuit
    End ---------------------------------------------------------------------
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,113
    9,123
    Im thinking users NHN or itwasntme187 for this. Try pm to them. Hope they can help you out.
  3. quattrojames
    14,050
    574
    Have you tried a replacment convenience module?
    If they get water damage from blocked plenum chamber drains or similar the effects can be very random.
  4. Cruiser89
    1,484
    221
    Yep... The module has been changed as per my first post.
    Like you say, they are prone to water ingress but this had none (I thought it would have been due to the signs)
  5. quattrojames
    14,050
    574
    I've just reread your first post, it mentions the module being repaired rather than replaced, unless I'm missing something.
    I would have thought you would see signs of water ingress, it's not something I've experienced first hand luckily.
  6. Cruiser89
    1,484
    221
    Yeaaa, I got another module from a breakers yard after the repaired one started doing funny things.
    Have seen water ingress in other cars. Looks like a small pond sometimes.
    Always happens, offer to help a mate out and it well an truly bites you on the backside. Just wanna get it sorted now.
  7. Cruiser89
    1,484
    221
    Figured it out, thought I'd let everybody know.
    Basically the new ECU I put in the A4 was a newer unit on the previous one and so had updated software. Turns out that the key will only work with a certain version of software. Popped to Audi and borrowed a spare key kicking around that would work with the software on the ECU.
    Moment of truth... Coded the key to the car with the existing blade and BOSH. Car remote now works and does everything as it should!! Good times!!
