Honda to Audi.....!! Sporty choice to Sensible choice....
Hulmie May 18, 2013
  1. Hulmie
    Hulmie New Member
    13
    Here is my old car, i traded it in for
    This......
    I'm well pleased with the B7 S-line SE with all add the options makes it a pleasure.
    Had the car for 5 weeks now and only a few issue with the B7.
    The dealership (honda) changed the oil coolant unit (not sure on the correct term) and flushed out the system 3 times before picking the car up after that and i'm still getting surplus oil in my coolant header tank took it back and flushed out the system and now still have the surplus oil in my coolant header tank.
    Yesterday driving to work the Min. oil light flashed up....! but after checking on the oil level this morning the level is at Max..!
    I'm a little confused could this be linked with the first issue or something much bigger???
    I never had a oil problem with my Type R and thats a high reving engine! Any idea or guidance would be welcomed.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,292
    10,252
    Hi, welcome to audi-sport.net. Someone will be along to advise you shortly. Enjoy the forum. :) x
  3. Craig Cull
    Craig Cull Well-Known Member
    2,428
    1,360
    Is the oil light amber or red mate?
  4. Craig Cull
    2,428
    1,360
    Sounds like loss of oil pressure, head gasket?? What engine is it? 2.0t fsi?
  5. Hulmie
    Hulmie New Member
    13
    It was amber mate. Like i said before don't know if the two issues are linked, but the oil levels are at Max...
  6. Hulmie
    Hulmie New Member
    13
    No 2.0 TDI 170
  7. Craig Cull
    2,428
    1,360
    Maybe just a faulty oil level sensor, amber is just oil level as far as I'm aware. The red one is a case of stop no matter what. That's the case on the 2.0t fsi anyway. Maybe someone with more knowledge on the diesel can help. Hope you sort it mate :)
  8. Hulmie
    Hulmie New Member
    13
    Cheers thanks for that. I might get it in at a VAG specialist for a look over.
  9. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Welcome to the forum mate. Looks like you've turned to the dark side of diesels as I did last year too haha. As mentioned above, yellow oil light is for oil level. I'd get diagnostic codes scanned to see if anything pops up, might be a faulty oil level sensor. Not difficult to replace but just means you have to replace your oil so I'd personally wait till the next oil service to get it done (if it is that which is the problem).
    Azeem
    Hulmie likes this.
  10. Hulmie
    Hulmie New Member
    13
  11. B_FUR
    B_FUR Active Member Audi A4 Audi Avant Owner Group
    494
    100
    43
    Nice looking car mate, welcome to the forum
  12. ESD1711
    ESD1711 Active Member
    691
    219
    43
    Haha pretty much the exact same move I made.... 55 plate premier edition CTR to a B7 diesel avant :)
  13. ben.w93
    ben.w93 Member
    213
    22
    Congratulations on your swap, that 170 engine is notorious for injector problems. We had a similar problem with oil in the header tank of our 170 Touran, went into VW and they did the infectors as a recal, ended up having a new engine and turbo with VW fitting the bill. Lost faith in the car and went into an A4. I hope I haven't scared you, but after our experience with that engine, I would stay clear of the 170.
  14. TOM.S
    TOM.S Active Member Silver Supporter
    564
    as said above it can be the oil level sensor,clogged oil pick up pipe-resulting in loss of oil pressure,or oil pump issues.get it checked scan for fault codes asap. if u leave it like that sooner or later u might get a serious issue, spending lots of cash on fixing/new engine in worst case.
