Home made Tyre Gel
Louay Mar 22, 2014
  1. Louay
    Louay Well-Known Member
    1,114
    516
    Has anyway ever considered a homemade tyre dressing?
    I normally use megs tyre gel but its quite expensive to keep buying, perhaps i should use something other than a brush to apply it which is probably why i get through a lot of the stuff.
    Just wondering if there are any homemade alternatives any one has used?
    thanks
  2. r15wne
    r15wne Member
    64
    10
    i have experimented with used engine oil......looked ok
  3. grchmason
    grchmason Active Member
    764
    239
    43
    LOL!! Peanut butter and your sorted!!!!!!!!
    Adam_A3_ and L33AEX like this.
  4. Louay
    1,114
    516
    smooth or nutty?
  5. grchmason
    764
    239
    43
    Smooth fella!
    Otherwise the bits go everywhere
    Louay likes this.
  6. Louay
    1,114
    516
    Presumably, organic is kinder to the rubber! Lol
  7. grchmason
    764
    239
    43
    Amen lol!!!!!!
    But **** me it's dear tescos blue stripe FTW!!
    Louay likes this.
  8. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    I'm not sure where I heard this exactly, but someone once suggested washing up liquid...
  9. L33AEX
    L33AEX Member VCDS Map User
    67
    Pretty sure that meg tyre shine is meant to last at least a few days? How often are you cleaning your car? Also how big are your tyres! I've got a bottle it lasts me at least 8 weeks! I clean my car at least 3 times a week.
    also use a sponge it spreads far easier and lasts longer... Try the meg tyre sponge.. :rock:
  10. Statler
    Statler Old enough to know better Team Daytona Team V6 Gold Supporter
    540
    410
    So I'm going to take this seriously... lol
    I mix Megs tyre gel with Greased Lightning Brilliant Black and apply with a paint brush. The sponge is ok, but it soaks up far too much and doesn't get the bottom of the tyre without moving the car.
    Brilliant Black Car Tyre & Exterior Trim Shine | Greased Lightning
    I use a small jam jar and mix it about 1/3 Megs to 2/3 GL - it lasts a few days in wet conditions, a week or more in the dry.
    It stretches the Megs out and the chemical mix hasn't killed me .... yet ;-)
  11. wxc
    wxc Member
    94
    27
    Halfords currently doing a 3 for 2 offer on all cleaning products, including the meguiar's tire dressing, one bottle has lasted me for nearly 2 years, a little goes a long way..
    And I personally wouldn't use a brush.. sponge application will always be the most suitable for gel based tire dressing
    batch and warren_S5 like this.
  12. Leebo310
    Leebo310 Member
    37
    Try FinishKare Top Kote tyre dressing mate. 32oz bottle can be found for £13 and lasts absolutely ages. You can spray directly on the wheel but I find too much gets on the alloy so it's much easier to spray onto an applicator pad and then apply.
    A couple of coats of that will last a while and even beads water off for the first few weeks!
    Oh and you can use it on interior surfaces, plastic grills etc too.
  13. mancdan
    mancdan Active Member
    491
    50
    +1 for me too on this. My bottle has lasted well over 2 years and I only apply with a Megs yellow applicator pad as it's easier to spread.
