kim gaardvik
Hi all,
have anyone knowledge enough to enable this on a car that have all the needed modules for this to work?
I have all the perquisites i.e all the modules needed :
The control units necessary for the Audi active lane assist function:
Camera control unit J852:
· Registers the area in front of the vehicle and transfers the images to the image processing control unit J851
· Searches for lane boundary lines in the images, determines their exact position and geometry, and transfers this infor- mation to the control unit J851
Image processing control unit J851:
· The function software of Audi active lane assist is integrated in this unit
· Transmits the required system steering moment to the control unit for power steering J500 and, if required, requests a vibration alarm
· Asks the control unit in dash panel insert J285 to display the current system state and, if required, to display messages and warnings
· Transfers the current system state to the control unit for windscreen projection J898 and asks it, if required, to display warnings
· Saves the settings for Audi active lane assist made via the MMI. The stored values are assigned to the vehicle key in use.
Power steering control unit J500:
· Activates the motor for electromechanical steering accor- ding to the specifications of the control unit J851 (generation of the required system steering moment and output of a vibration warning)
· Reads in the sensor for steering moment G269 and forwards the steering moment to the control unit J851
Optional control units that can be used if fitted:
Adaptive cruise control unit J428 and control unit 2 for adaptive cruise control J850:
⢠If the vehicle has the optional extra ACC, its measured variables are used for the two functions "Deliberate lane change without set turn indicator" and "System characteris- tics with obstacles detected on the neighbouring lane"
