hit a grave! help!
paultaylor Oct 25, 2004
  1. paultaylor
    paultaylor Member
    294
    Need your advice, hit a very sharp edge a dodgy road works gas cover last nite, almighty bang, couldn't believe the tyre didn't blow and the rim was undamaged(no visible damage but the rim could be buckled now) I stopped to take a look and you could see where the tyre had taken the impact, it's no cut but there is a small blister on the sidewall which would indicate sidewall damage. my concern is that on the 9-spoke RS4 rims with P-Zero Rosso tyres 225/40 R18 92Y at 36psi is there a huge risk of a blowout particularly under heavy cornering load? The tracking seems ok and it still steers straight.
    There's only a thousand miles left in the fronts so should I change them now to prevent the possiblity of going off big style if the tyre let's go??
    Any advice would be much appreciated
    Black 02 S3 225
  2. PaulRS3
    PaulRS3 Well-Known Member
    1,230
    156
    tyre + blister = answer.. get it changed immediately.
    your talking £165 each tops per tyre, against ££££'s of pounds in damage, excess, future insurace hikes if you have a blow out/crash.
    without going into killing yourself and or someone else.
  3. mdoyle69
    mdoyle69 Member
    140
    In my opinion mate i wouldnt take a chance.....
    if there is any unseen damage to the tyre i suppose the chance of a blowout is pretty high. Especially if its to the side wall.
    And if you only have minimal tread left i would just go ahead and change both tyres and get the wheel inspected while they put the new ones on.
    Hope that helps mate /ubbthreads/images/graemlins/beerchug.gif
  4. paultaylor
    paultaylor Member
    294
    that's what I thought, I'll order the tyres now, any other inspection I could do?
    I'll have a the tracking checked at least no?
    It was 1mm toed out as far as I can remember, any thoughts anyone?
  5. paultaylor
    paultaylor Member
    294
    cheers for the quick response, top forum this!
  6. cybrey
    cybrey Member
    331
    [ QUOTE ]
    [/ QUOTE ]
    With that kinda of impact you'll probably need to get a full aliignment check done, from Audi these aren't cheap. I personally wouldn't rely on what Quickfit or similar do.
    Oh and as everyone else has said .. replace the tyre with the blister.
  7. GregC
    GregC Member
    278
    DEFINATELY get a specialist or AUDI dealer to check the alignment if in any doubt - Quickfit are just as likely to set your car up as a Fiat Tipo as an A3! I have been there.
    Greg.
  8. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Get it checked by a 4WD alignment specialist.
    Don't want to be the voice of doom, but I did a similar thing in my old Mk3 GTi. It took a chunk out of the alloy, but the tyre didn't blow. Steered straight, no pulling to left or right.
    However on further inspection, the wheel had moved about an inch to the rear. Got it checked and needed £1500 of new suspension.
  9. paultaylor
    paultaylor Member
    294
    Ordered two new P-Zero Rossos today 225/40/ 18 92y for 370 euro(don't know how this price compares to the UK but it's good for Ireland)
    Gonna have the Audi dealer do four wheel alignment when there changing the suspension bushes that have been causing that pain in the ass "creaking noise" that other members have reported.
    Question for AndyMac, how was the suspension on your Mk3 damaged?
    cheers for the feedback
  10. The911SC
    The911SC Active Member
    1,032
    If you can find the offending dodgy cover, and it is still broken; you may be able to get some money from the highways dept in the local council. It is their responsibility to keep the roads repaired, and there is a procedure for compensation.
    Take a video or photo of it before they rush out snd fix it!
  11. AndyMac
    9,832
    46
    Paul, it was a company car so I didn't really pay much attention to the bill when I picked up the car. I seem to remember the front strut got pushed back, along with various control arms & tie rods. Sorry to be so vague. They probably charged the insurance company £400 just for the new alloy/tyre.
  12. paultaylor
    paultaylor Member
    294
    ouch! well hopefully it's just the tyre seeing as there's no visible damage to the rim. cheers
