Hissing sound when accelerating
colej Feb 8, 2010
  1. colej
    colej New Member
    Hi
    This question may have been answered before, as found some threads concerning it on the a4 forum but nothing on the a3 forum.
    Just bought a 2001 audi a3 1.9Tdi and have noticed when accelerating it makes a hissing sound. This is audible when you have the window down. It seems to happens at low rpm (about 1500-2500), it does not seem to happen when idling or when just revving the engine. Is it meant to make this noise?
    Any help would be appreciated. Thanks
  2. sulaiman
    sulaiman Member
    274
    Sounds like the turbo boosting which you should be very happy of. lol
  3. MIKE GTR
    MIKE GTR Member
    366
    I know this sound, i had it on mine, it sounds like air escaping. Do the normal checks on all boost pipes etc - I could never find mine
  4. kitpayne
    kitpayne Member
    129
    I had a 1.9tdi passat which made the same noise. it ended up being a straight piece of rubber pipe near the turbo somewhere. not sure which pipe though!!
  5. jdas03
    jdas03 Member
    603
    I get that on mine all the time presume just the turbo, since i have owned thr car its made that hissing noise
  6. martin1
    martin1 New Member
    well i don't know about anyone but i like this hissing sound :p
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    It's got boost leak written all over it.....
  8. lee111s
    lee111s Member
    54
    Are you sure it's not just the turbo sucky noise :D
  9. Welly
    10,696
    127
    That's not really a hiss though, more of a whine....
    Bottom line here is that the facts are a bit sparse!
  10. sportstractor
    sportstractor Chugger
    2,709
    any major leak will be quite obvious on performance and MPG.
    Boost leaks aare a ******** fiind, just a massive process of elimination. I took mine for a smoke test and they found a little leak, still managed to find another leak afterward.
  11. Welly
    10,696
    127
    Tell me about it, I'm still hunting them down at the moment, after fitting the intercooler 2 months ago!
  12. gewagon
    gewagon New Member
    Hi I have an Audi 1.9tdi 05 driving it the other day heard a slight pop and then the turbo has a loud whining/hissing noise , when I took of the wastegate acuator pipe (vacume) the noise stopped but lack of turbo power when I put the pipe back on I had full turbo power but the whining turbo spinning noise like the wastegate is constantly open , could this be the N75 Solinoid valve or an air leak somewhere I dont think the turbo is at fault as it is not rumbling or rattleling or like a bearing whine just the spinning noise of the turbo ?
  13. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    Mine does the same :-s
  14. jwb7
    jwb7 New Member
    Hi
    Just got an A4 1.9 tdi 98 s plate and i too have this bloody anoying high pitched whining noise, and when I remove the small pipe from the vacuum unit it stops, anybody replaced this N75 valve there talking about and did it stop the noise? I have checked the turbo fan and there doesn't seem to be any free play or looseness there
  15. gewagon
    gewagon New Member
    anybody have any idea what this problem is ?
  16. steviet
    steviet Member
    439
    Whats the smoke test??...
  17. shanejess
    shanejess Guest
    if your tyre is now flat it was a puncture nothing to worry about.
  18. jwb7
    jwb7 New Member
    Took my A4 to an Audi mechanic yesterday and he says it's normal turbo noise,, well pleased as I thought major expense on the way
