Hissing noise in the background
danilotto Apr 22, 2014
  1. danilotto
    danilotto Active Member Audi S3
    191
    Hi all,
    Just to know if it is the same on your S3s...
    I notice a slight background hissing noise when the car moves from standstill. It is not the turbo spinning, it reminds me the noise of a brake pad creeping on the disk or the butcher's slicing machine lol.
    Did you notice it?
  2. BigD289
    BigD289 Member
    104
    13
    Fan on your amplifier? Check under the passengers seat.
  3. BigD289
    BigD289 Member
    104
    13
    For RHD models!
  4. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    957
    394
  5. Scott
    Scott Well-Known Member
    1,306
    126
    I get a noise but it's from idle too so not when I move off
  6. danilotto
    191
    Sorry I did not understand.
    Nope, it is another thing. When I move from standstill (mine is S-Tronic) I hear in the background a slight hissing noise it is something like expanding gas noise when you switch on the A/C but it is not the A/C at all. It comes from the front.
    Maybe something related to the vacuum pump of the servo brake?
  7. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,764
    Hi
    For the past 2 days, I have noticed a very similar noise. Like a quiet hissing, similar to when your aircon system is low on gas, and it is moving through the pipes.
    I can only hear this:
    In an indoor Multi storey car park
    It is very quiet
    Only when the steering wheel is turned to almost 1 full rotation
    It doesn't make the noise (or is very quiet) when the steering wheel is straight ahead
    So far I've only heard it at slow ish speeds
    Did you find out where the noise is coming from?
  8. 6audi6
    6audi6 Member
    33
    21
    I have exactly the same issue between 1000-2000 rpm. There is already another thread as regards this 'metallic rustle' as previously mentioned. I'm not too sure this isn't one and the same to a varying degree?
    To be honest, unless it gets any louder, it doesn't unduly concern me. It may just be a trait of the car (I stand to be corrected). Mine goes back to the dealers next week to get the S tronic gearbox checked out. I will mention the noise and see what they say.
  9. veeeight
    6,849
    4,764
    On mine, this is a completely different sound to the metallic rustle/tinkling noise, which is the wastegate actuator rod.
  10. veeeight
    6,849
    4,764
  11. danilotto
    191
    Uhm, I read the golf R thread and they write about a steered wheels situation. The hissing noise I noticed is constant also going straight. As louder as stronger is the acceleration, it is not related to engine revs and this make me think it is related to transmission and not to engine. It is like the brake pad rubbing against the disk.
    I had the car checked by two different Audi dealer. The first said that it could be related to the S-Tronic clutches, the other did not notice the noise (lol)
    It could be interesting to know if only S-Tronic experience this noise or also manual.
    EDIT: my big concern is that it could be the hissing noise: R Forum • View topic - R mk7 Turbo failure!
