Hiss on cold start up??
walla Jan 29, 2012
  1. walla
    walla New Member
    Hi guys, i've got a a3 quattro and ive noticed something strange with my car. When starting up the car cold it'l rev at 1,200 rpm for a few minutes and then settle slowly down to about 800rpm. Now not sure if this is normal but it's always been like that.
    However now ive noticed that just before it starts to drop there a very distinctive hiss. Is this normal??
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Revs will always be higher on cold start and they will drop as the engine warms but yours might be a bit high.
    If I was you I'd stick your head under the bonnet and see if you can pin point the hiss as it sounds like you might have a split hose somewhere.
  3. <tuffty/>
    21,777
    4,165
    Its most likely the SAI... if its hissing then it could be that the vacuum pipe has been disconected... yours had an N249 bypass or something?
  4. Dani_B19
    9,360
    399
    Do you have the aircon on when starting up? If my air cons on when i first start the car, you get a whining/hissing noise.
  5. walla
    walla New Member
    Just stuck my head under the bonnet (luckily its cold outside so it didnt take long for the engine to get cold)
    Theres definitely a small click before the hiss, almost like a switch clicking by the battery. The hiss it self is coming from the front of the car below the throttle body. Not sure if it makes a difference but i have the Electronic throttle on mine.
  6. Y83OLK
    Y83OLK Hulk Smash!
    841
    Sound like the a/c fan.. see if it does it with the climate set to Econ.
  7. walla
    walla New Member
    The air conditioning/heater was off at the time.
  8. <tuffty/>
    21,777
    4,165
    SAI....
  9. <tuffty/>
    21,777
    4,165
    ...or a vacuum leak from the PCV...
  10. walla
    walla New Member
    any ideas on repairs costs etc.
    and how it would affect my cars performance
  11. QuattroRich
    QuattroRich Quattro Formaggio
    30
    I have an A3 quattro and have this hissing sound coming from the same place. Only seems to have come about now the cold weather has set in and disappears once the engine has warmed up after a couple of minutes.
    Can this problem be solved easily?
  12. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    It's the SAI as tuffty said. My 2 tqs' have both done/do this...
  13. QuattroRich
    30
    Cheers Reesy, will look into it
  14. Reesy
    3,640
    148
    Shouldn't need to mate, if it makes a noise and then cuts off as the revs drop, its more then likely working fine. Mainly happens when car and ambient temp are cold.
  15. QuattroRich
    30
    I was hoping that it was just due to outside temp. Cheers fella
