Hill hold assist
johnnevett Jul 25, 2013
  1. johnnevett
    johnnevett Member
    245
    19
    Hi all
    is hill hold assist a retrofit option for the b8?
    Is it just a case of installing the right switch and programming?
    Is there any guides anywhere to help do this ?
    cheers
    john
  2. NHN
    29,333
    1,717
    Requires abs module to be compatible.
  3. johnnevett
    johnnevett Member
    245
    19
    Thanks for the reply
    how do I check if the module is compatible
    cheers
  4. NHN
    29,333
    1,717
    With vcds, check if its got the option.
  5. johnnevett
    johnnevett Member
    245
    19
    Ok, thanks.
    if the option is there is it just the switch that would be needed?
  6. Leeroy1
    Leeroy1 New Member
    14
    Is this just the auto hand brake release when you pull away?
    i just thought it was a standard feature?
  7. Stonefish
    Stonefish Active Member
    182
    51
  8. johnnevett
    johnnevett Member
    245
    19
    No, it's a different switch which makes the car hold when stationary once engaged you don't have to keep pressing it like the normal hand brake switch
    Audi Dynamik likes this.
  9. Spr0cket
    Spr0cket Member
    114
    You also need to run wiring from the ABS module in engine bay to the new switch in the centre console.
  10. johnnevett
    johnnevett Member
    245
    19
    Even if the option is already there in vcds like mentioned above?
    Is there a guide to this wiring if not
    cheers
  11. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
