Higher wattage bulbs
Chris-gsxr Feb 7, 2013
  1. Chris-gsxr
    Chris-gsxr Member
    57
    I've heard the horror stories about higher wattage bulbs, potentially causing fire or melting the headlight. Are higher watt bulbs really a big no no?
    I've upgraded the head light bulbs but they are still not as bright as I was hoping for. Ive heard the more expensive Bulbs aren't all that Amazing either so What's everyone's opinion on higher wattage? dose anyone use them in their car, if so any problems?
    09 A3 sline
  2. Camerz
    Camerz Member
    66
    10
    i have a 09 sline and have 80 watt bulbs for dipped beam and i have had no problems.
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    IceHanger likes this.
  4. mike foster
    3,967
    Anything over 55 watts is illegal for road use in UK.
    Despite what is said about 'no problems', the wiring circuit is designed for 55 watt bulbs and a 45% increase in current load to 80 watts is unsafe. Also the increase in heat generated puts the plastic reflector in danger of melting.
    However, it is of course, your choice !
  5. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Big no no. Used them on my old car, melted the connectors, inside the head unit and cracked the headlight lenses.
