Higher compression ratio in an s3?
ian52 Dec 7, 2011
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Basically im running an ARY engine in my s3 instead of an APY engine so now i have 9.5 to 1 comp ratio instead of 9 to 1. Can anybody think of anything that i should be wary of or look out for running higher compression? I know i have 19mm wrist pins before anybody mentions that. Just thought i would check to make sure.
  2. <tuffty/>
    21,962
    4,229
    High boost will be the biggest issue... high comp ratio, high boost, higher cylinder pressure, weaker rods...
    As you have had issues with boost (in a previous thread) then cap it with an MBC...
  3. ian52
    1,199
    Yeah,im just running it at 5 psi just now with the n75 unplugged. Getting a manual controller to plumb in with it off my mate to see how it goes. Im just running it on super unleaded too.
  4. Andrew@A.L.D
    3,879
    617
    Welly is running that compression ratio but he has the rods to take that pressure
