dultanur
all promises, no action :)
hi guys!
i think my car has a wierd water temp. problem. when stuck in traffic, 15degrees C outside, the water temp as seen from block 49 on the aircon is between 98-102. i've even seen 103. isn't this a bit high? i also have an oil temp gauge and thats also hovering between 100-105, so the reading seems correct.
on the other hand when cruising in 6th at around 100kph, the same shows around 70 degrees (oil temp also). and it won't heat up anymore unless i "give it some stick" or get stuck in traffic.
so what do you guys think? is this normal? have you checked this on your cars?
thanks!
thanks!
