high speed cornering = warning light
s3tle Aug 11, 2004
  1. s3tle
    s3tle Member
    239
    hello
    i've got a a3 without the computer bit between dials which only has a warning light to tell you somethings wrong and not what it is. On a particular bit of road i drive along, a tight cornered exit sliproad which doubles back on itself so quite long too, each time i drive it at 70ish the warning light comes on and although definatly because of the corner i not sure why. The car has also got coilovers fitted and lowered about 100mm and doesn't have esp or traction control. i think i've check all the obivous things, levels, brake pads and discs etc but all are fine. So bit lost as to what is wrong or whether its just the cars ecu getting a bit confused as the warning light goes out after the corner
    thanks for any help
  2. SanityClause
    SanityClause Member
    93
    I've had various cars where warning lights flash on a tight corner, usually it was for any of the fluids.
    The fluids, (oil, water, brake, clutch, screenwash) slosh to the other side during a tight corner.
    If the fluid level is slightly low it will trigger an alert, so make sure all your levels are topped up, then try it again.
  3. Are you sure it's not the ESP traction control kicking in? If the wheels are in danger of skidding the traction control takes over, reduces the power, and the warning light comes on. The same light comes on if you turn off the ESP system.
    Not sure if this is the same light you mean.
  4. Kevint
    Kevint Active Member
    1,182
    He does not have ESP or Traction Control.
    I like the idea that a fluid sensor is being uncovered whist tight cornering, sounds sensible.
    Kev.
  5. Gambba
    Gambba Active Member
    1,361
    What light is it exactly??
  6. neil.c
    neil.c Senior
    568
    I would check the oil level and brake fluid level as you are getting surge in the corner, if it is the oil light it is because the oil pickup in the sump is being uncovered so starving the engine of oil, which will lead to damage!
  7. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Could be the coolant sensor as that went on mine last year.
    I used to park on a hill and the sensor put a fault on the dash saying I had low fluid............but when the car was level it stayed on unless I started the car a couple of times before it went.
