High pitched noise
Camerz Mar 6, 2013
  1. Camerz
    Camerz Member
    66
    10
    On my way to college this morning and realised my car was making quite a high pitched noise when crawling in traffic. Tried to figure out the position of the throttle, speed etc but it was impossible due to it being different times when the noise started. Mainly in 1st and 2nd when crawling. Just wondering if anyone had any ideas, obvious thing to do would be to get it checked under warranty but its easier if you have a rough idea what it is. Btw its a 2009 1.4t fsi
  2. Tay
    Tay Active Member VCDS Map User
    449
    55
    What kind of high pitched noise? Was it different with the clutch pressed or not?
    I'm wondering if it could be anything gearbox/clutch/diff related.
  3. Camerz
    Camerz Member
    66
    10
    Still there when the clutch was pressed
  4. Jack_tdi
    Jack_tdi Member
    287
    12
    I had a brake disc dust cover come loose have a look at them.
    Or brake pads?
  5. max69vk
    max69vk Active Member
    862
    57
    It will be your EGR valve, totally normal & nothing to worry about.
  6. Camerz
    Camerz Member
    66
    10
    makes quite a high pitched noise like metal on metal?
  7. dancupra225
    dancupra225 Active Member
    667
    25
    Egr connection pipe have split mine has and makes a Noise like that
  8. Ash187
    7,520
    758
    U trapped your gf under the bonnet??
    Jack_tdi likes this.
  9. lau06275
    lau06275 Member
    42
    Out of interest on another matter, how many miles has your car done so far? Have you experienced any engine related problems?
  10. Jack_tdi
    Jack_tdi Member
    287
    12
    Have you checked brakes?
  11. Lukus87
    Lukus87 New Member
    13
    Thats interesting, i just had an iduction kit fitted and im getting the same i though it was the heat sheild rubbing on the fire wall or something, will check the EGR pipping now and report back
