High pitched noise from rear speakers
Jay4 Aug 28, 2007
  1. Jay4
    Jay4 Member
    50
    i've recently swapped the Concert 2 headunit in the car for another (non audi) headunit and am getting a high pitched noise from the rear speakers when the headunit is switched on. The noise is constant so is not too bad at high volume but if the headunit is fairly low on volume, the high pitched noise can be heared through. Any ideas what this could be?
  2. AndyMac
    9,832
    45
    Is it alternator whine (does it go up & down with the revs) or something else?
    If it is then try earthing the chassis of the HU to the cars chassis behind the glovebox. Also what adapter are you using to connect the new HU to the rear amp?
  3. Jay4
    Jay4 Member
    50
  4. AndyMac
    9,832
    45
    that's the speaker input adapter which could be the issue. Essentially it's taking the amplified speaker signal from the new HU and reducing it down to a pre-out signal, only to be re-amplified again by the Audi rear amp. This is prone to creating electrical noise as the hi-lo converter is bound to be poor quality.
    Maybe worth trying the RCA input adapter (as long as the new HU has rear RCA's) as this is a far cleaner solution.
  5. jase0851
    jase0851 Member
    789
    i just ran new wires from the headunit to the connector block in the rear which was pluged into the amp, under andys advice, and the rears work a treat now much better than before. need to wire up the head unit properly next
  6. D9n dk
    D9n dk Dan Klang Audi A4 S-line owners group Team Akoya
    587
    332
    Hey sorry to drag up a really old thread but here is my problem
    I've fitted an aftermarket head unit with the same adapter you have used and I too get a buzzing from the rear speakers that's driving me mad. I've been searching and searching the Internet and have found a couple of threads where people have the same problem but in all the threads no one has an answer or can cure it or get around it. This is the only thread I've seen where it may be possible please could you tell me what new wires you run from the adapter to the rear amp as i want to do this thank you or does anyone else know many thanks
  7. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    basically
    try running a rear rca output from your headunit into the standard amplifier as opposed to two convertors
