High milage service.
Rough Jul 19, 2010
  1. Rough
    Rough Member
    75
    My 1.8tqs has just turned 94k so she'll be needing a service soon, whats the best grade of oil for this engine as all the books at work list 10w40 semi, and what else should i do to keep her in good condition. (water pump tensioners and belt replaced 1k ago)
  2. finesse
    finesse Active Member
    2,805
    Spark plugs, filters(oil,air,fuel,pollen) oil - 5W40
    gearbox oil, rear diff, haldex
  3. madvw
    madvw Active Member
    2,489
    sump pump and strainer check and clean.
  4. Matt82
    Matt82 Active Member
    2,365
    pas fluid, brake fluid, coolant
    tbh... just do what needs to be done. 94k isnt a lot of mileage anyway, just carry out the servicing thats necessary if you care enough and if you really want it to be bullet proof, do the non service schedule items too
  5. Rough
    Rough Member
    75
    is it ok to use an engine flush before an oil change?
