High level brake light
J0N35Y Jan 6, 2013
  1. J0N35Y
    J0N35Y Member
    67
    Hey guys, I've noticed that half the high level brake light has stopped working on my car. Is it a sealed unit or are there bulbs that can be replaced??
  2. J0N35Y
    J0N35Y Member
    67
    And also, I feel a bit embarrassed to ask this but how the hell do you get the brake light out??
  3. lukey baby
    lukey baby Member
    106
    12
    They are LEDs in a sealed units.
    If it is a saloon then i believe you disconnect the wiring and use a screwdriver to release the retaining clips and then remove the light.
    If it is an avant then you've got to remove the tail gate trim, put a screwdriver in the wiring hole in the tailgate and slide the retaining rail to the right and then remove the light starting at the right side.
  4. J0N35Y
    J0N35Y Member
    67
    Thank you so much. I have trawled various forums and nobody ever seemed to answer the question. It's an avant so I will have to have a look. Is there no way to get into the light at all? Was thinking of soldering new led's or trying to clean up the connections inside seen as its intermittant.
  5. lukey baby
    lukey baby Member
    106
    12
    Not that i know but you may find that the time it takes it maybe worth just buying a new one
