High level brake light bulb change
TimG Nov 2, 2010
  1. TimG
    TimG Active Member
    942
    45
    Probs the lamest question ever, but Im guessing its a case of just pulling hard at the trim to get it off, held in by those clip thingys, then the bulbs are accessable?
    Thought Id just double check before I go breaking anything :)
  2. maxp
    maxp Member
    70
    Yep they are, did mine a few months ago, all for the sake of one bulb (ocd much).
    I think there might just be one (maybe two) screws to undo (near the bottom of the boot)
    It was then just a case of easing off the clips (there are loads of them).
    Sorry for being a bit vague, its in the haynes though.
  3. NoggyS3
    NoggyS3 Member
    242
    Glad you asked this TimG.
    Got to replace a bulb myself.
    @Maxp, where did you get your bulb from dude? Stealer?
  4. maxp
    maxp Member
    70
    Yep theres a dealer a few mins away from me. The new one was noticebly brighter than the others, so I replaced a working but old bulb on the other end of the cluster to 'even' them up.
  5. NoggyS3
    NoggyS3 Member
    242
    Thanks for that mate :icon_thumright:
    Will sort this the weekend if weather is o.k!
  6. JohnStan725
    JohnStan725 Member
    147
    9
    Hi Guys, i know this is an old post do you know what the type of bulb it is so i can purchase these? Name of the bulb for example will be appreciated.
    Thanks!
  7. daithi23
    daithi23 Active Member
    236
    25
    It's a dealership bulb I think, and if I read correctly before, you need to replace all of them at the one time. If you put in one new one it will change the electrical draw on the others and result in the old ones blowing quickly. Plus you'd have an odd brightness!
  8. IanPG
    IanPG Well-Known Member Team Nogaro Blue Silver Supporter Audi S3
    1,234
    482
  9. Nath1790
    Nath1790 Member
    104
    17
    As above, I changed all mine at the weekend as 3 were out. Ordered box of 10 online for around £5 I think. Very simple and they are indeed tiny!
  10. newbster
    newbster Active Member
    302
    71
    don't want to be an internet ****, but the above is b****ks, i'm an elec eng, so know a little of what I speak of
    different electrical draw will make no difference to the other bulbs, in this case, there are good reasons to change all at the same time
    different brightness
    the old bulbs are just that, old, easily over 10 years old now, so if one fails, the rest are due anyways, this may lead to the impression that changing one caused the others to fail
    its a bitch to get to, stand a good chance of breaking the plastic bits if you have to take the trim bits off 10 times
  11. daithi23
    236
    25
    As I said, 'if I read correctly' I was open to be corrected as I wasn't sure. Thanks for clearing that up for me and for others.
  12. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    165
    58
    just google T5 capless bulbs, same thing, i replaced mine with some ebay led t5's i bought a few years ago, it was $2 for 10 bulbs if i remember correctly.
  13. newbster
    302
    71
    noted, wasn't intended to flame you, just correcting the info :)
