  1. Kostas
    Kostas Member
    104
    balast has to fit flush otherwise you wont get the light back in
  2. chrisash32
    chrisash32 Member
    573
    thanks, you wouldn't happen to know how thick your ballast is do you? I want to measure it against mine..
    i guess yours only just fit?
  3. Kostas
    Kostas Member
    104
    not too sure but I think it is about 25mm you can get away with
  4. chrisash32
    chrisash32 Member
    573
    thanks, i will measure mine...
    Will post some pics in a bit!
  5. Kostas
    Kostas Member
    104
    is it due to bad wether or my hid conversion done something to my radio once a week I'm driving from essex to Bristol somewhere halfway I started to loose radio signal rds stoped working or something it never happened before. Any thoughs?
  6. Kostas
    Kostas Member
    104
    also 4300k has brown strip going down the side of the bulb 6000k has white strip acording to the seller so i've got 4300k which I'm very pleased with (strip=couted wire going down the side of bulb)
  7. quattrojames
    14,068
    584
    Hit me with that in English? :search:
  8. chrisash32
    chrisash32 Member
    573
    the radio antennas on the A4's are in the rear screen so HID's shouldnt affect it...
  9. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    So why should this affect it ? I always thought they were in the boot lid!
  10. chrisash32
    chrisash32 Member
    573
    sorry, my bad! was supposed to say "shouldn't"...
    I remember reading somewhere in the past that its the two vertical lines up the rear screen.. Serving as two radio antennas... And on some models they signal swap so to ensure when listening to national radio (e.g., Radio 1 / Radio 2) the car should never loose signal between different regions. As whilst your listening on one tuner, the other is looking for a better / stronger signal. When one is found they swap...
    I am sure i read it online, or watched it on the Audi channel... Will have a mooch about to see if i can find some more info.
  11. Kostas
    Kostas Member
    104
    it was raining heavily this morning it might be just wether
  12. Kostas
    Kostas Member
    104
    the problem is they never swaped as they used to do last week:blush:
  13. quattrojames
    14,068
    584
    I play my ipod through an FM transmittor, and when I turn the HID's on I get a lot of static interference until the ballasts have warmed up fully.
  14. Kostas
    Kostas Member
    104
    how long it takes them to warm up?
  15. chrisash32
    chrisash32 Member
    573
  16. quattrojames
    14,068
    584
    About 30 secs - but some interference remains all they time they are on. Fitting a suppressor would probably eliminate that all together.
  17. chrisash32
    chrisash32 Member
    573
    hmmm, i didn't get any 'noise' in my old car...
  18. pjmspeedy
    1,058
    There the ones I bought last week and so far so good :icon_thumright:
  19. quattrojames
    14,068
    584
    Maybe depends on the location of the ballasts, mine are quite near the bulkhead.
  20. Kostas
    Kostas Member
    104
  21. chrisash32
    chrisash32 Member
    573
    Excellent, no flickering etc etc? Also, what bulbs did you go for?
    Finally, where did you install all the gear? would it fit in that little section under the light like the images on the previous page?
    Cheers!!
  22. chrisash32
    chrisash32 Member
    573
  23. Kostas
    Kostas Member
    104
    as I said so far so good 4300k is the ones to go for :yes:
  24. Kostas
    Kostas Member
    104
    love the moment you turn them on :arco:
  25. pjmspeedy
    1,058
    No flickering at all. I went for 4300k as I didn't want them to look illegal and plus I bought them for maximum light to see.:w00t:
    On the passenger side it was all installed in the empty box thing that sits in front of the header tank. All bolted to the side of that using the holes already in it. When the RS4 washer bottle cover is in place you can't see them at all.
    Drivers side is strapped to the shelf that the light sits on and the igniter is also secured in the big empty space that is there. Again once the headlight is back in place you can't see them at all :)
  26. pjmspeedy
    1,058
    Me too :rock:
  27. chrisash32
    chrisash32 Member
    573
    me three!
    not sure which of the two to get now!! I do like that under light install quite a lot!!!
  28. chrisash32
    chrisash32 Member
    573
    Kostas, do your bulbs have a plastic or metal base?
  29. pjmspeedy
    1,058
    I couldn't do that on mine as the Cab lights are different.
  30. Kostas
    Kostas Member
    104
    metal but I don't think it has ceramic insulation tho
  31. Kostas
    Kostas Member
    104
    it might have just not white
  32. chrisash32
    chrisash32 Member
    573
    yeh, i only realised this evening my old £200 ones are plastic and it has put me off them slightly!
    Really am torn which kit to go for now!
  33. Kostas
    Kostas Member
    104
    I had the same problem as you have just throw a coin I'm sure they bouth good kits
  34. chrisash32
    chrisash32 Member
    573
    I am inclined to go for yours as i like how they are installed... on that basis only.. you say they fit well etc etc? plenty of room for some plastic straps maybe? or even a plastic cover to go on that box area?
    on the other hand... i do prefer the advert form the other seller lol
  35. Kostas
    Kostas Member
    104
    the manual do recomend to fix it in wentilated area so I gues plastic cover isn't an option but straps well recomended
  36. pjmspeedy
    1,058
    I think mine are great and i'm really happy with them but the others seem very good too and are being sold by a well known company. Go with what you think is the best kit for you!
    Don't be tempted by the advert because you make **** things look good!
  37. chrisash32
    chrisash32 Member
    573
    ok, straps it is then!
    How long did they take to deliver?
  38. Kostas
    Kostas Member
    104
    the seller suplayed me with a right product in a wrong box but was very helpfull after sorting it out
  39. Kostas
    Kostas Member
    104
    payed 10ish got 3ish next day
  40. pjmspeedy
    1,058
