Hids in a 8p 2013
LEE69 Dec 1, 2013
  1. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,316
    410
    Mates just put them in his, car not the high priced kit but a canbus kit from ebay.
    His he likely to suffer the windscreen motor problem?
  2. NHN
    29,577
    1,779
    Probably.
  3. LEE69
    2,316
    410
    Ta does it do it over time or is normally a quick fail?
  4. c_w
    c_w Well-Known Member
    1,169
    91
    It's nothing to do with the canbus error correction. Or even what setting the car is on with VCDS (ie halogen or xenon headlights). It appears to be the voltage draw and feedback from the ballasts. One of the first aftermarket kits I got off ebay I think I, and many friends who bought them at the time, were lucky that they were quality kits (even though they were cheap). Most of the ballasts on ebay kits (the slim black ones with the external igniter boxes) are rubbish giving flickery bulbs etc.
    If you can wire stuff up, you could get a set of OEM ballasts (off any car, not just VAG) and see if you can get them to work with the aftermarket bulbs (can't see why not). This would be a safer option.
    LEE69 likes this.
  5. LEE69
    2,316
    410
  6. blazedani
    blazedani Guest
    He most likely will end up blowing his wiper motor...
    The wiper motor can be repaired once it happens.
    There are special HID kits for Audi A3, regular HID kits are not safe.
    Search in the forum and you will find plenty of info.
  7. leegsi
    leegsi Active Member
    489
    57
    Cant you do the earth mod like on the B6 A4's?
  8. LEE69
    2,316
    410
    Just found this makes sense
  9. leegsi
    489
    57
    On the A4 they have started by cutting the earth from the headlight and earthing that wire (From the headlight) to a different point.
    That way you are taking the problem away from all the other earths rather than just protecting the wiper motor.
    LEE69 likes this.
  10. LEE69
    2,316
    410
    If you got a relay loom, that goes to the battery anyway, and only uses the original light power as a trigger for the relay, which then powers the ballasts.
  11. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    Can you link us to one of these relays? i am well up for trying a wiper blowing kit, but with all the possible fixes!
  12. JJ.Foulds
    1,263
    176
  13. LEE69
    2,316
    410
  14. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Tell him to ditch the HID's and either stump up the cash for the proper Xenon's or fit some 'oncoming-driver-friendly' Osram Nightbreakers or Philips Xtreme Vision bulbs and still have a functioning wiper motor.
    Btw warranty won't cover the wiper motor if the HID's blow it.
    DomH likes this.
  15. blazedani
    blazedani Guest
    That information is wrong.
    There is no power going back through the earth system.
    The problem is very simple, 25.000V cables produce interference. As simple as that.
    Has been proved during years in other Audi forums, nothing new to rediscover.
    There is no harness relay in the world that can prevent that since the interference are spread by air.
    If someone wants to keep trying to rediscover the problem he will most likely end up with another broken wiper motor.
    Since 2003 people have been trying warning cancelers, relays, battery harness, different grounding, using Fog lights circuit.... all of them proved nothing.
    All you can think has been proved before.
    There is a solution already to avoid the problem Not to use regular HID kits since they produce interference.
    Only some special HID kits & some OEM are interference free.
  16. JJ.Foulds
    1,263
    176
    so dani? where could I buy such a product?
    Ch3tan likes this.
  17. blazedani
    blazedani Guest
  18. blazedani
    blazedani Guest
    I know this guy from swedespeed.
    Many fancy words & not a single solution.
    He recommended a couple of relay harness, using "KBOWE" as he call it (basically a warning canceller) & even using the Fog lights cables to power the HID kits.
    Some users that tried his "solutions" had broken wiper motors few months later.
    You can not use cheap HID kits & make them safe for the wiper motor.
    As you can see... some people try, they are lucky & they recommend to do something that blows away the wiper motor to someone else.
    This is what happened to the people who tried the "solutions" from the guy in Swedespeed.
    People are just guessing with the battery harness, relays, resistors, etc...
    If the wiper motor didn't blow away for some people is just good luck & is not proving anything, since others using the same setup do blow away theirs.
  19. a6_chris
    1,883
    160
  20. blazedani
    blazedani Guest
    I thought we were talking about HID kits in this thread.
    Who is talking about headlights?
  21. a6_chris
    1,883
    160
    I quoted your post which was relating to selling both?
    But anyway, it doesn't matter.
  22. NHN
    29,577
    1,779
    Maybe Blazedani can reply to one of our members that bought one of his hid kits & so far has received no correspondence at all, they even started a thread to complain about this aswell, I suggest you reply to the guy, we all know its your company anyway.
    a6_chris likes this.
  23. JJ.Foulds
    1,263
    176
    please let him become sponsor, then no1 buy anything.
  24. JJ.Foulds
    1,263
    176
