HID's - any issues i should be made aware of?
drewbee Feb 9, 2010
  1. drewbee
    drewbee Member
    196
    im getting HIDs fitted this week, and i was wondering if anyone has them fitted and experienced any problems with them?
    mines going to be fitted with cancelling units from a company called autolights.
  2. aragorn
    18,134
    764
    Presumably your ignoring the fact that they're illegal, unless fitted with automatic load levelling and a high pressure washing system, and are fitted in type approved headlamp units...
  3. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
  4. paul20v
    paul20v Audi fanatic
    1,113
    It should also be illegal to fit **** headlights on a car OEM but that doesnt stop audi with the B6 ,
    theres a lot of things that are illegal do you stick to them all ?
    Its hardly a capital offence is it !!
  5. Nutkin
    Nutkin Member
    830
    bloody hell why does someone have to come on and ruin a thread by lying through it, Nowhere has said its illegal and all the documents people throw up have no withstanding laws afiliated to them.
    Law states in simple terms the headlights are to be white and correctly leveled to not dazzle people.
    my HIDs are in projector lenses and leveled.
    All these people claiming illegalitys? What about cars that came standard without washer jets and without leveling before the saftey standard came into effect?
    Should they be made illegal now?
  6. quattrojames
    14,050
    575
    That's not strictly correct, and aragorn does have a point....
    Whilst the majority of people running projector headlights will get through the Mot no problems, DOT legislation states that retrofitting xenon lights is illegal.
    The full article is HERE
  7. defsix
    defsix Member
    181
    But aren't the B6 housings the same except for the lamp mounting inside ? My headlight has both Halogen and Xenon markings...
  8. paul20v
    1,113
    "quattrojames"
    This is true , but theres far more important things that are not right than a set of bulbs
    i done it as a safety thing as i already said the B6 lights are disgusting to the point of dangerous
    people also put high wattage bulbs in wich are not emarked thats illegal too
    the list gets endless and at the end of the day if there set up correctly in projector lights no harm done
    lets be honest how many Discovery , range rover , X5 Zenons have you come across that are nice for oncoming cars and there stock with all requirements
    theres so many things that people do to there cars which is far more serious .
    rant over :)
  9. quattrojames
    14,050
    575
    I agreed entirely mate, I didn't write the article, just quoted it ;)
  10. Nutkin
    Nutkin Member
    830
    Not worth the paper its printed on, its merely a VIEW and wouldnt hold up in any case against a stop and search on a car unless the officer could proove it was a danger to other road users. It is also only their view when the light casing isnt meant to house the xenon bulb, where the B6 A4 is designed in this way and is adjustable so.
    I still refer also to the series 1 renault laguna when Xenons first apeared they had them without projectors or washer jets. the suspension was self leveling anyway.
  11. quattrojames
    14,050
    575
    I'm no lawyer, but I think it's a little bit more than that, it forms part of the 1988 Road Traffic Act.
  12. J7USS
    J7USS Shuddup Foooool!!
    3,737
    76
    Now now folks!!:)
    Drewbee - You shouldnt have any probs really. Some have had issues with the Ballasts causing their dash to light up with errors such as ABS/bulb out warnings but nothing that major, just annoying! You have the cancellers too so you should be ok!
  13. drewbee
    drewbee Member
    196
    Cheers J7USS.
    cant wait to get these fitted.
  14. aragorn
    18,134
    764
    I'm just making you aware of the actual legal stance.
    The UK construction and use regulations make no provision for HID's at all. This means that HID's arent allowed to be used in the UK. It states that quite clearly in the DOT article linked above. Manufacturers get round this by holding European type approval for their designs, and vehicles which hold this can be used in the UK, ie it overrules the C&U regs. However fitting them to a non-type approved headlamp unit, without the prerequisite auto levelling and washing systems, would not meet the type approval, and is therefore illegal.
    Nutkin: If you'd actually read the article you'd see that while yes, the article represents the departments "view" it also quotes the LEGAL stance. Read the 3 paragraphs under "The following is the legal rationale:", and understand what its saying.
    The light housing ISN'T designed to take a HID bulb. If you think it is, i'm sure you'll see the problem if you tried to fit the proper D2S type approved lamp into the H7 socket in your halogen projectors...
    You mention a laguna, no where in the regs does it say they require projectors for HID's, plenty cars exist with reflector based HID setups. Self levelling suspension is also fine for the levelling aspect. Not sure how they got round the washers though.
  15. Amir
    Amir Member
    74
    I've seen many flicker.. aslong as they 35w ballasts and not 50w you should be fine
  16. sc00byd00byd00
    sc00byd00byd00 Frank and Beans............... VCDS Map User
    230
    Mine are 50w and are fine........... AND just passed an MOT with them fitted
  17. J7USS
    3,737
    76
    Whats the difference with the 35w and the 50w anyway apart from Power wise????
  18. golf
    golf ***** rent boy VCDS Map User
    1,556
    I can't wait until they make aftermarket xenon kits illegal [​IMG]
  19. reggieroo
    reggieroo Member
    259
    Why?
  20. reggieroo
    reggieroo Member
    259
    http://www.audi-sport.net/vb/showthread.php?84093-HID-S
  21. golf
    1,556
    So I won't get blinded by 8000k kits in headlights designed for halogen bulbs.
  22. head
    head Member
    283
    lol you'll love mine i got 12000k 1s to blind you..
    if the kits were illigal they would not pass m.o.t.ive had the same kit on a couple cars and they all passed
  23. chrisash32
    chrisash32 Member
    573
    8000k is stupid!!! less than 5000k is acceptable!
  24. reggieroo
    reggieroo Member
    259
    The higher the kelvin the less bright they are, 5000k are brighter than 8000k. What about cars that have both fitted like A4? I have fitted 6000k HID's in mine but it could have came with factory HID's. Do you just hate any car with good headlights like new Range Rover, Mercedes etc?
  25. quattrojames
    14,050
    575
    The higher the Kelvin the more blue the light which is what I find dazzling. I think Golf's point, which is one I agree with, is that when HID's are fitted to cars with reflector headlights they can be dangerously dazzling. Our A4's all have projector headlights which are more suitable for HID's as they suffer reduced light scatter. Any manufacturer fitting xenon lights as standard will use a projector unit.
    Anything above 6000k is looks over function in my opinion anyway.
  26. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,094
    329
    So next time when I drive next to coppers in Volvo V70 I will stop and tell them to switch off the lights because they have no projector lights.
  27. ronny
    ronny Audi A4 1.8TQ
    131
    D2S is for a projector/ellipsoidal housing.. D2R is for a reflector housing
    Different bulbs for different type of headlights, i will say this(changing the subject slightly) I drive about 40k miles a year and have looked at lots of different cars headlights, I can tell you that it has got to be a myth that OEM use 4300k Xenons, I think 5000/6000k are more like what is used, i have 4300k in mine and if you park it up next to a Q7 for example the blue hue is much more visable, this is the same for almost all HID OEM lights i have seen.
    i know people say the housing make a difference, but a projector is a projector the optics are almost identical apart from the beam cut offs, i would say OEM is more likely to be 5000k.
  28. reggieroo
    reggieroo Member
    259
    The same as H7R for example, for reflector housing. These were sent on my first kit & when I looked up the difference between H7 & H7R I found that the H7R is an anti glare bulb for reflector headlamps. Wrong bulbs for me though has my lights are projector.
    I know what you mean about OEM lights being really blue sometimes, a new laguna passed me yesterday on the back roads & the lights were the bluest I'd seen. Also an 09 Vectra I seen yesterday had really blue headlights & I thought surly they must be more than 4300K.
  29. quattrojames
    14,050
    575
    I think Audi use 4300k for their lights, maybe other manufacturers use different ratings. Certainly the new Mazda 6's look very blue.
    I stand corrected then in that case.
  30. golf
    1,556
    I didn't say shitty aftermarket kits were illegal, I said I couldn't wait for them to be illegal. I'm sure you can see very far with your purple lights anyway...
    You'll have to rephrase that, I don't know what you mean. If you look through my previous posts you'll see that I'm a bit of a xenon nut, and I don't hate good headlights, I actually spend hours researching them. Sad, I know!
    It is actually the beam cutoff which gives the illusion of a higher kelvin rated bulb. All projectors are very different. To the uninitiated they look the same, but each one has differing properties which produce varying beam patterns, colour and cutoff. All manufacturers fit either 4100k or 4300k from the factory. The only reason some look bluer than others is the design of the projectors, nothing else. After a few years some of the Philips 4300k xenon bulbs are designed to colourshift, so look closer to 4600k. Apparently BMW briefly fitted 5000k's to some models but went back to 4300k almost immediately.
    I used this image below of an Audi A4's OEM xenon headlights to explain how colour flicker is achieved:
  31. simon.m
    simon.m Active Member
    2,747
    hi guys how can i tell what lights i have mine have the blue/purple line at the top
  32. reggieroo
    reggieroo Member
    259
    [​IMG] Originally Posted by golf [​IMG]
    So you understand that people want to just improve their headlights then, not piss off other road users? I fitted them to our A4 as it's the misses car & she drives home late, in the dark on lots of back roads from work for 35 miles each night. I thought the standard halogens were **** to be honest & wanted her drive home to be safer.
