  1. Andyroo83
    Andyroo83 Member
    46
    Are these kits anygood off ebay? Do they just plug in and play? Are they used instead of the main beam bulb?
    SPanks!
  2. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I've had a set on my old Clio, but since buying an audi and coming on here, I've read they damage your wiper motor. If you also do a search you'll find a thread about H7r bulbs which have a loom which "apparently" prevents this and has a sort of black ring on the bulbs to prevent blinding on comers.
    I don't think anyone has tested these bulbs yet though to see if they work but there around 150 quid iirc
  3. southylad
    southylad Active Member
    544
    I had a cheap kit on my passat for 2 years no probs you put them on the dipped beam normally but you can have them on both as above i have read that on the audi they damage the wiper motor as the share a comon earth
  4. aragorn
    17,962
    702
    Some of the ebay kits are utter ****, and most of the bulbs are fairly rubbish, because the salts required to make good quality bulbs are expensive.
    Theres also various legal issues to deal with (though many people simply ignore)
    Personally, i'd try to use as many OEM components as you can. You can get used ballasts for £30ish if you know what ones you need. I'd want to use genuine Osram D2S bulbs and use a converter plate to allow them to fit into your halogen projector.
    If you have old reflector headlamps then you really shouldnt be fitting them at all, upgrade to facelift lamps, then convert those.
  5. Andyroo83
    Andyroo83 Member
    46
    Ive read some of the old msgs on forum about them. Think i may pass on them. And eventually upgrade headlamps. Just that the older headlamp are utter ****. Ive upgraded bulbs on them and still ****.
  6. Oranoco
    Oranoco Well-Known Member
    3,803
    349
    I obtained my kit from Amazon of all places. Can't fault it really. Have to on large agree with aragorns comments.
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    have two kits from HIDsdirect
    about £50 IIRC had a ballast replaced under warranty early on but otherwise faultless
    connectors can be a bit cheap but a zip tie and or some tape sorted them
  8. Ben S3 8P3
    Ben S3 8P3 Member
    313
    32
    Ive bought a few sets of HID's in the past from the HIDs Direct shop near Manchester. They have a website here - HIDS DIRECT LTD Store
    They are also good for other LED bulbs etc
  9. blazedani
    blazedani Guest
    Aftermarket HID kits only damage the wiper motor in this vehicles:
    - Audi A3 8P (almost all of them)
    - Golf V (lower rate)
    - Seat Leon mk2
    - Peugeot 407
    - Volvo S40
    For the Audi A4 any aftermarket HID is 100% safe. No matter the quality of the HID it will never blow away your wiper motor.
