HID KIT Confusion.................?
Jack_tdi Mar 12, 2012
  1. Jack_tdi
    Jack_tdi Member
    287
    12
    Hello All
    Just signed up to this forum today iv had my 2006 A3 for a month now and miss my HID's i had in my corsa. My Audi has normal filament lamps and i feel the vision just isnt as good.
    I have read about the after market HID kits on the likes of Ebay blowing window wiper motors
    i have read a few topics and found people talking about these........D1S Xenon HID Bulbs
    I have a few Questions.....
    How does the Aftermarket HID kits blow wiper motors......???
    and are the sets in the link above going to do the same thing.....? or are they for cars with HID as standard....? and will they fit if i bought some.....?
    Thanks in advance Jack
  2. c_w
    c_w Well-Known Member
    1,163
    87
    Those and other D1S HID bulbs are OEM fitment, so they won't work with aftermarket HID kits unless you are very handy with electronics!
    Nobody seems to give a proper answer as to why the motors blow on the A3 when using aftermarket kits, some blow instantly, some take a while to blow, then some kits claim to solve the issue (one is a HID kit from Spain called Welldone) completely.
  3. Lewbo
    Lewbo Well-Known Member
    1,266
    104
    The wipers share the same earthing point as the headlights as far as I know so this send spikes down to them and blows them up, some last 5 mins and some last few months, but I wouldn't ever have them, think of the other drivers you are blinding, plus they are now illegal.
    Just buy updated bulbs instead or go down oem route and get xenons fitted but this isn't cheap.
  4. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    Don't do it, they're **** anyway.
  5. Jack_tdi
    Jack_tdi Member
    287
    12
    the headlights share the same earth point as the wiper motors....???
    surely then if you take the negative from the ballast and bolt it to earth (the chassis) this would solve the issue.......
  6. Jack_tdi
    Jack_tdi Member
    287
    12
    and what is the difference between the ebay ones and the OEM ones surely they will spike too.....?
  7. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Many people on this forum and other sites had problems with their wiper motor after fitting aftermarket HID kits. It is your car and your money. We are just trying to help.
  8. Jack_tdi
    Jack_tdi Member
    287
    12
    im not doubting any ones knowledge or experience i am just curious as to why this is an issue and why it hasnt been solved....
    what exactly happens to the motor ....?
    is the wiper motor a servo....?
  9. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,235
    328
    when you turn them on they power spike the wipers causing the wiper ecu to blow i think , I've been stung by this so have many others in short don't do it the only way is to buy oem
  10. Jack_tdi
    Jack_tdi Member
    287
    12
    what will i need for the OEM's too fit i assume they wont just fit straight in.....
  11. LEW1S.W
    LEW1S.W Member
    50
    If its the bi xenons u will need well over a grand!!!!
  12. Jack_tdi
    Jack_tdi Member
    287
    12
    stick to the halogens then just wait and buy an s3 if i want xenon/HID :)
    id still like to know if this could be solved though just because im curious now lol
  13. NHN
    29,331
    1,716
    I have 3 sets of bixenons for sale, 2 sets of bixenons & 1 set of bixenon adaptives, PM if interested.
  14. Ash187
    7,486
    738
    Remember that when installing the OEM headlights the car is coded to tell it that it has xenon and not halogen which is why it wont blow the wipers. where as the hid kits just replace the halogen bulbs but do not operate properly on the given voltage.
  15. Jack_tdi
    Jack_tdi Member
    287
    12
    sounds like its more hassle and more money than its worth im just gonna stick to my halogens get soem whiter ones maybe....
  16. jeanlegro
    jeanlegro New Member
    I just installed hids for my fog lights on my white Audi a4 2012. FIrst of all, the hid kit that I installed is a 55w canbus 8000k. Installation is easy and should take you max 30 minutes to complete the installation. Behind the bumper, where the wheels are, you need to remove the 2 screws and then you can directly get your hand to the fog lights. Once you reach the bulb installation take 5 minutes. You connect the hid kit together and the you connect the hid kit to the factory harness. My hid kit cost me 110$ shipping included and the kit also come with a lifetime warranty. I attach some picture of my xenon lights on my fog lights. If anyone have any question on the installation or where i got my hid kit..... PM ME
    i took 4 pictures late last night:
  17. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,255
    586
    It's easy to solve the wiper motor issue. Use the headlight feed to turn on a relay which is connected to the battery and powers the bulbs.
    Rick
  18. 16vt
    16vt New Member
    17
    Has anyone tried retrofitting different projectors altogether into the headlight? There are some superior projectors out there for a fraction of the price bixenons go for.
  19. Broken Byzan
    13,237
    465
    DOes the bulb warning not have a fit?
  20. Jack_tdi
    Jack_tdi Member
    287
    12
    I assume i will have to trick the ecu into thinking the relay coil is pulling the same current as a standard bulb......?
  21. Jack_tdi
    Jack_tdi Member
    287
    12
    im going to try and make a loom ill report when iv finished :)
  22. Chris Grundy
    Chris Grundy New Member
    Definitely don't install HID's!!! I have a 07 sportback and after only 1 week of stupidly installing some, not only have they blown the motor but also another part ( not sure what yet as I still haven't got the car back). £560 it's going to cost me...!!!!! ABSOLUTLEY WOUNDED.
  23. fangio
    fangio Well-Known Member
    1,482
    175
  24. FranA3
    7,235
    328
    ouch what else has blow bud , mine just blew the wiper motor luckily and cost me £370 to fix , i don't understand why people are still trying to fit these they are well known for blowing wipers never doing it again to my car thats for dam sure
  25. andi1
    andi1 WWW.APR-REMAPS.CO.UK
    220
  26. h5djr
    9,399
    1,736
    Does the kit include the necessary auto-levelling and headlamp washers. If not the car would be illegal.
  27. Jack_tdi
    Jack_tdi Member
    287
    12
    thers a few cars with xenon/hid as standard but no light washer
    clio 172
    evo 8
    iv had a little look at some pics of an evo x and didnt notice any wahser either
    Will they Fail an MOT????
  28. Jack_tdi
    Jack_tdi Member
    287
    12
    iv knocked this "project" on the head. im just making do with halogens cant be bothered with any hassle plus im trying to save for a house so dont need a massive bill to repair the motor :D
  29. 3DTDi
    3DTDi Member
    239
    A clio 172 and evo 8 dont have xenon headlights as standard, they may well have been an optional extra and people have retrofitted them without the washers. Also there are a lot of cars with projector headlights which still have halogen bulbs like the facelifted evo 8, 2008 megane, 2007 vectra etc etc.
    Many people get taken in by the if it passed the mot it must be legal theory but officially this is not the case.
  30. Jack_tdi
    Jack_tdi Member
    287
    12
    Evo ten has headlight washers
    I just read on wikipedia that 8 and 9 mr editions have hids
    But as far as im aware no washers....
  31. 3DTDi
    3DTDi Member
    239
    If its a uk spec car then if it has xenon headlights the it will have washers as uk cars have to meet vosa requirements. An evo mr version might have xenon headlights but it will also have washers
  32. h5djr
    9,399
    1,736
    If you have halogens the best option to get more light is just to go for uprated bulbs. Osram and Philips both do suitable bulbs and these do not cause any problems with the wiring and do not require washers or auto-levelling and the car remains legal.
