HID install (picture heavy!)
jcb Oct 4, 2009
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    not that deep,its a scuff from a car bumper by the look of it.
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
  3. ian52
    1,199
    think ill give it a go with some wet/dry and some polish.
  4. manzi
    manzi Member
    64
    I've previously bought a H4 hi/lo (or however you say it, HID main beam, normal small bulb for other) HID kit, to my knowledge, all i need is the right bulbs to use this kit ......right? as ballasts are fine.
    what size/type do i need?
    cheers
  5. impster
    impster Member
    92
    great guide there - just fitted mine. 'like a glove' as you say.
    Quick question - in my kit there are 2 extra bags of cables - each with a 20w 10ohm resistor. What's that for? any ideas?
  6. aragorn
    18,438
    845
    at a guess, its to fool some kinda bulb monitoring system that everythings working ok?
    The A4 ones designed for HID's anyway, so it should be happy.
  7. Geeman
    Geeman Low Life
    1,318
    Extra cables with resistors...?
    Send them my way! My M3 needs them as the bulb check keeps throwing up bulb errors!
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    yep, only required on flighty systems.
    mine pops a code every no wna dthen when I turn them off but it is instantaneous and goes as quick as it came.
    have some resistors here also if anyone wants them.
    thought I had a dead ballast last week, turned out to be a loose connector.
