HID install (picture heavy!)
jcb Oct 4, 2009
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    So I finally plumped for vision at night instead of fumbling my way around the countryside,
    got a set of 50W 5000k H7's from HID Direct. Car is facelift B5 avant so already has Valeo projectors fitted.
    instructions seemed pretty straightforward and I am no electrician so was a little concerned it would be trciky.
    Whip the head light out - two torx screws on the top of the unit, one at the lower side behind the indicator accessed through the hole near the edge of the wing. bit tricky but you can get your hand down to grab the screw and torx bit.
    unit wiggles out away from centre. two plugs to disconnect and you can retire to the warmth.
    rear of unit:
    OEM Balast recess in bottom of unit:
    Instructions call for a 25mm hole drilled into bulb cover, but I didn't like that idea and it also means the cables are all over the place.
    drill the hole through the base where the balast will be.
    Balast test fitted......like a glove:
    hole for cable routing:
    cable fitted with grommet in place (f. tight fit!):
    all wrapped up ready to be tested back in place:
    view from the back, sticks out at the bottom but there is a surprising amount of room below the headlight.all the joints are pressure fit water tight, was going to seal them all in a bag but didn't in the end.
    The ballast is a very tight pressure fit into the OEM recess but I screwed it in with a plastic strap just in case and cable tied the loose cables to the edge of the recess.
    end result:
    let there be light, HID right, H7 halogen left, photos don't really show the difference but it really is night and day :
    job done.
    Obviously I have headlight washers and self levelling mechanisms in place to comply with the legal requirement........
  2. Siena
    Siena Active Member
    2,626
    Nice job.
    Did you retrofit self levellers? As it was only fitted to cars with factory HID'd.
  3. jcb
    4,132
    13
    Ah.....not quite done that bit yet....
    you were doing a retrofit weren't you? did you pull a kit together or something like that?
  4. PaulJC84
    PaulJC84 Owner
    2,904
    17
    I think he was maybe joking about the self levelers.
    Oops too late!
    Nice job, your wires are done a bit neater then mine!
  5. aragorn
    18,299
    804
    if you want a kit, kufatec sell one,
    otherwise just buy the brackets, ecu and sensors etc from a breaker and wire it up yourself.
  6. Siena
    Siena Active Member
    2,626
    I did put one together, and fitted it to my own car before I copied it!
    I'm going to build another master kit though, so it's easy to knock more up at short notice.
  7. jcb
    4,132
    13
    interested but at 259 euros for the kit they are steep
  8. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    aragorn is it this one here?
  9. jcb
    4,132
    13
    you need the brackets as well 259 not 89
  10. aragorn
    18,299
    804
    you can always pull the brackets, sensors and ECU out of a breaker, then just use the loom from kufatec, which should work out cheaper, but if you've got access to a breaker, you may as well just get the loom plugs and make the loom up yourself too.
    The A8 and probably other models use the same ECU and sensors, so you can always get the sensors and ecu from one of them and then just buy the bracket from audi for your particular model
  11. jcb
    4,132
    13
    what exactly does it do?
    alter the headlight position constantly as you go up and down?
  12. aragorn
    18,299
    804
    Pretty much.
    I'm not sure if it constantly does it, or if it takes an average over a period of time or what, but basically if you stick two folk, or a pile of bricks or whatever in the back of ANY a4 (well any car at all really), your supposed to adjust the little knob on the dash to the appropriate setting for the load to keep the headlight declination at the required 1%. Very few people even know what the knob is for, let alone use it, so on HID equipped cars where the beam is much brighter, the law says the headlights must automatically level themselves regardless of vehicle loading etc.
  13. jcb
    4,132
    13
    ah, I actually use that knob quite a bit as the car is usually 5 up with a boot full of bikes, bags and bricks!
    you can see the beam pattern coming further up the road signs when it like that
  14. aragorn
    18,299
    804
    Yer, but thats becuase you actually have a brain!
    Far too many drivers dont, and wouldnt even notice the lights pointing skywards...
  15. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    whats the light like at night?
    my ebay cheapies look bright but illuminate the road about the same as a birthday cake candle
    i think i need to fit a better kit or possibly just better bulbs
  16. jcb
    4,132
    13
    will tell you later when I fit the other set to my main beams!!
  17. Geeman
    Geeman Low Life
    1,318
    I've got retro-fitted HID's on my facelift. Night-time vision with them is great.
    I'm glad I read this thread though as I never knew about the little 'pouch' for the ballasts under the headlight units... mine are fixed in some weird places in the engine bay. Now I know this, I can re-locate them neatly. Brill!
  18. jcb
    4,132
    13
    did you do the whole auto levelling system?
  19. Geeman
    Geeman Low Life
    1,318
    They were already fitted when I bought the car.
    And, if anyone in 'authority' wants to know, the autolevelling device is, of course, fully installed and working perfectly.
    Not.
  20. aragorn
    18,299
    804
    HID mains?
    Seems a little pointless to me, you'll lose your ability to flash people, or if it does still work, then you'll be giving the ballasts a hard time...
    I also dont find anything wrong with the halogen mains?
  21. Geeman
    Geeman Low Life
    1,318
    Mains...?
    Mine are only dipped... I've still got the original bulbs for main beam. (and you can tell as the light is really yellow compared to the dipped HID's!)
    Think he's got a bit confuzzled...
  22. aragorn
    18,299
    804
  23. jcb
    4,132
    13
    nope, not confuzzled.
    Plenty of Cars have seperate HID dipped and mains as opposed to sheilded BiXenon with the mask. Lexus, Mercedes, BMW etc etc
    They don't die as quickly as people make out from flashing, they just don't light as quickly or as brightly as halogens when flashed.
    In fact the Lexus IS200 flashes both main and dip when you flash.
    mine are now also so **** and yellow that you can hardly bloody see the difference!
    I will let you know if they die in two weeks time though. never one to avoid admitting I am wrong.
  24. aragorn
    18,299
    804
    How quickly do they actually fire up? I know the OEM ones are pretty fast, but i'm sure i've heard the cheap ebay ones can take a number of seconds to fire, rendering them useless for flashing anyway.
  25. jcb
    4,132
    13
    oh no, these are very quick, otherwise I wouldn't consider it.
    less than a second certainly, can't say for sure but there is no delay.
    I would say it is a case of click of the switch, a quick flicker and then the light full on.
  26. jcb
    4,132
    13
    Right then, the build continues.
    Main beam HID's. Only issue is the ballast position is taken up with the other ones now so I had to be creative.
    I hate seeing wires everywhere so I routed the harness through the base again and hid the HID under the front panel under the headlight housing.
    Underside of headlight showing driving (dipped) light HID ballast and Main (Full) beam harness on the left:
    quick coat of matt black and the ballast blends in nicely:
    view from the top when fitted and cables nicely zipped up under the light housing:
    no wires for the MOT man to get excited about. "Must be OEM with self levelling as standard"!
    and for anyone concerned about losing their flashability:
    looks fine to me.
    pattern and level to be checked tonight when dark.....the suspense is killing me!
  27. aragorn
    18,299
    804
  28. jcb
    4,132
    13
    cheers.
    TBH its not rocket science, you just need a straight wal and a flat surface.
    Nice dark car park down the road here so will see if I can get some decent pics.
    looking forward to seeing where I am going at night!!
  29. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    I used a couple of blobs of Blue-Tac on a wall to level and centre my lights when I went facelift. Quick, easy and accurate!
  30. Spacecowboy
    Spacecowboy Member
    367
    How easy is it togo facelift? Anytime I do a search on here it brings back results for all areas of the forum :-(
  31. rasA4
    3,287
    119
  32. Oranoco
    Oranoco Well-Known Member
    3,913
    391
    It's bloody scary to do but the results speak for themselves
    Before
    After
    Really not sure what I was thinking with those crystal indicators though. Ahhh well.
  33. jcb
    4,132
    13
    you just need some HIDs now!!
  34. Spacecowboy
    Spacecowboy Member
    367
    Cheers guys Il check out those links and will no doubt be back!
  35. aragorn
    18,299
    804
    scary? yep! Didnt stop be hitting it with the angle grinder though :D
  36. Spacecowboy
    Spacecowboy Member
    367
    Still trying to find a how to on this otherwise I'll just 'sympathetically' start grinding away!
  37. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    just done mine. only on low beam but i can see at nite now! much better. my driver side lamp has a scuff on it and its surprised me how much less light you get from it compared to the other side.
  38. rasA4
    3,287
    119
    Great stuff Ian, get that sorted asap as you may dazzle someone else
  39. ian52
    1,199
    tempted to machine polish it but the lens is plastic so not sure if it will work. you realy notice the beam pattern now as being \__ shape now that its bright enough to see properly.
  40. rasA4
    3,287
    119
    you will need to wet sand them 1st lots of stuff on google etc. then polish them up after. How bad is the scratch, is it deep?
