  1. DriveByShooters
    DriveByShooters Editor Audi-Sport.Net Magazine
    1,189
    Looking to put a HID bulb kit in my A4 B5. Is there anything i should look for in a kit?
    And am i right in thinking, the higher the "k" number, the bluer the light and in turn the less use they are.
    Will i have problems with plastic headlights and heat etc?:uhm:
  2. Broken Byzan
    13,237
    465
    You are correct on the Kelvin number. The OEM colour is 4300k, i have found 6000k to be as blue as is useful.
    The plastic lenses causes no problems as the HIDs run cooler
  3. DriveByShooters
    1,189
    Thats cool (pardon the pun)...i know the early HID's weren't to be used with plastic lens but that was some time ago.
    I think you're right in going for the 6000k....they seem to be the brightest you can get. 3x brighter than halogens apparently.
  4. Broken Byzan
    13,237
    465
    I personaly having tried both temps, prefer the whiter light afforded by the 4300ks. We have 6000ks in the A3 and although much better than normal bulbs, there is more light available from the A4 with 4300ks.
    PS Where is the gallery?
  5. griswold
    griswold Member
    350
    I have 6000k in mine here is h7 on left hid on right
  6. Siena
    Siena Active Member
    2,626
    I wouldn't go higher than 4,300k either.
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    any reputable kits?, I tried to by some OEM HID but the bast@rd on RS246 stiffed me on the money and has yet to return it!
  8. aragorn
    18,315
    809
    I'd also like to know how OEM facelift HID's compare to a set of facelift halogens retrofitted with a (good) HID kit, and which HID kits are worth the money...
    I'm wondering if the projectors are different at all meaning the OEM HID's gives a better beam pattern...
