Hi new to site and need some advice..............
A3driver Dec 12, 2011
  1. A3driver
    A3driver New Member
    Hi, have A3 early 2000 model 140,000 miles. had hesitation problem with car, sounded quite muffled and throaty if that makes sense. felt like even with foot hard to floor it wasnt going anywhere. not revving properly. blew head gasket, just replaced that but problem stillthere. dont want to blow gasket again so looking for advice. i have just realised that if car starts first time on key with no accelarator at all the car runs fantastic, but if i have to touch the throttle at all to start her thats when the problems begin...... the only option is to pull over and wait til i can start her without using the throttle. Any ideas???
  2. <tuffty/>
    21,672
    4,101
    Hi and welcome to the site :)
    First thing you will need to do is check for fault codes... what engine code is yours? AUM or AGU? can't remember when the change over was...
    All the usual culprits should be checked... vacuum and boost pipes/hoses etc... try running the car with the MAF unplugged to see if things improve (would suggest faulty MAF if it does))
    But other than visual checks you really need to check fault codes as it could be explained away simply from any you may have...
  3. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Hi mate welcome to asn. As for your problems its best to get vag com on it to see if theres any fault codes. Could be coil packs or split boost pipe or breather pipes, most likely ones under the inlet manifold. Good luck.
  4. A3driver
    A3driver New Member
    hi, its a AKL engine. 1.6. there is no engine management light on. tonight i left work and drove for 5 miles abosolutely fine. stopped for 45 mins. started it first time on the key no accelerator needed. pulled away in 1st fine, went into 2nd and immediately it lagged. had to stop and retry starting it...same again, 3rd time drove the mile home no probs. coil pack was replaced about 3 months ago.
  5. camscockle20vT
    1,740
    77
    Oh thought you had a 1.8 turbo for some reason lol could need a good service, im not sure about the 1.6's
  6. patTTpoa
    patTTpoa Member
    793
    I'm thinking possible blocked cat
    Pat
  7. <tuffty/>
    21,672
    4,101
    Fault check first :)
    Same regardless of engine tbh...
  8. Ashley g
    Ashley g Member
    171
    I'm also thinking blocked cat! Disconnect the exhaust and see if it revs a bit more freely
  9. A3driver
    A3driver New Member
    Hi, have had a guy out to track fault codes and he says im showing 3 -
    lambda sensor
    throttle actuator
    and throttle control sensor
    im sure it cant be all 3 things gone at once so which would be the best/easiest one to go for.
    cheers.
  10. <tuffty/>
    21,672
    4,101
    Any chance you can post the actual fault codes?
    You can then look them up here
    Category:Fault Codes - Ross-Tech Wiki
    ..and make a start diagnosing... what you have posted isn't enough really..
