Hi..new and need some wheel help.
jonesy07 Mar 26, 2013
  1. jonesy07
    jonesy07 New Member
    22
    Hi guys,
    I am new and already calling on you for help.
    I was a member on RS246 as i have has a couple of RS4's but just made theswitch to a S3 and loving it !
    I am unfortunately not too clued up on wheels and looking to change my Black editionsfor the same but in 19's.
    Will the following fit :
    19X8.5,ET 45,PCD 5X112, C.B 66.6
    I was planning on running spacers but i know certain ET'swill fill the arch more. Also what tyre width is best to avoid any rubbing taking into account i will add 25mm H&R's.
    Thanks in advance for any help and explanation tomy ignorance.
  2. TDI140
    TDI140 Well-Known Member
    1,632
    175
    They will fit on your a3, you need to remove the rear arch screws and run 215/35/19 tyres (stretched) and thats all, you should be ok and also be able to drop around 45mm aswel
  3. br20vt
    br20vt Active Member
    199
    56
    They'll work fine with anything up to a 235 tyre, and as above remove the rear arch screws to avoid the annoying scrubs over bumps.
