hi just joined the forum. question about exhaust sensors.
S3 STEF Jan 20, 2012
  1. S3 STEF
    S3 STEF New Member
    I had my 2001 s3 in for a service at star performance & one of the advisory notes was that the exhaust gas temp sensor was faulty.i never queried it as the garage owner was not there.i have since had a look around the car & there are two sensors.what issues would the car have if one of these sensors was faulty?there is no warning light on the dash & i am not noticing any real drop in performance.
    is this something that would only be picked up checking for fault codes?lastly which one of the two sensors is it likley to be at fault?
    thanks
  2. <tuffty/>
    21,139
    3,828
    If its the EGT sensor then thats in the turbo measuring the exhaust gas temps and the sensor box is under the inlet manifold... unfortunately if thats the issue then its not a cheap sensor... 150 to 180 quid iirc...
    Signs of the EGT sensor not working are typically bad fuel consumption as the EGT sensor is an important sensor and the ECU will just go into a self preservation mode...
    Best bet is to get it checked (if you can) for fault codes and get them to tell you what they are so we can have a go at diagnosing the issue..
    Star Performance have a good reputation so the diagnosis should be sound tbh...
    There is only one EGT sensor, the other sensor could be the Lambda..
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    The EGT sensor is in the turbo housing, assuming u have a later amk or bam s3? EGT sensor is there as a protection sensor, when it reaches a pre set temperature due to high exhaust gas temperatures it will trigger a function in the ecu to dump more fuel in to engine too cool it. Ie make he mixture richer. If its faulty, then it'll either come into early and you'll get a rich afr early or it will come in late and you'll get high egt's with no protection. Neither is good Really, to Be safe just drive carefully till its sorted so egt's protection doesn't trigger.
  4. beachbuggy
    1,931
    201
    Or what he said :)
  5. <tuffty/>
    21,139
    3,828
    Should mention that if the ECU can't get a signal from the sensor it will be rich all the time... this is a bad thing not only for your fuel consumption but also in terms of engine wear as the cylinders will see bore wash from the excessive fuel...
  6. S3 STEF
    S3 STEF New Member
    its amk. this EGT sensor is one that i wasn't aware of. if it was the lambda i was going to try & tackle it myself.
    popping back through to star performance tomorrow for diagnosis.had the car five years & take it to star performance for all servicing & issues.
  7. S3 STEF
    S3 STEF New Member
    cheers tuffty. i take it you have had similar issues?
  8. beachbuggy
    1,931
    201
    EGT sensor is easier to remove and replace than the lambda. Have ago yourself, but make sure it's faulty first as its £150 ish to replace!
  9. <tuffty/>
    21,139
    3,828
    Yeah... had issues as a result of putting the EGT probe into the manifold when I first did my BT conversion but have since moved it to the downpipe which got me out of a hole...
    I managed to damage the sensor electronics and had it intermittently working for a while... in a recent bit of work I did on the car I noticed my piston rings had worn excessively... had plenty of similar mileage engines apart to know that was not normal and put it down to the time I ran with the EGT probe playing up and bore washing the cylinders stripping all the oil from them...
    No harm in asking Star for the code but if it is the EGT probe it not cheap sadly...
  10. Jimgrim77
    Jimgrim77 Member
    957
    20
    I picked up a new EGT last week for about £90+vat.
    pre-remap the car was showing very different readings from turbo to exhaust tip.
    My mileage is now 130k and with that mileage it was somewhat expected.
  11. <tuffty/>
    21,139
    3,828
    ...from???
  12. Jimgrim77
    Jimgrim77 Member
    957
    20
    Ha...that was inevitable. Useless comment without source.
    Apologies. I'll make a call and find out. I had it sourced for me by my tuner and am seeing him next wednesday worst case scenario as I'm settling up this work and a few other pieces.
    Will post and advise when I have it.
  13. S3 STEF
    S3 STEF New Member
    Guys you were correct about the EGT sensor. spoke to the boss at star performance on sat who explained what it did.
    thing is,he said it not working properly was not an issue & not to worry about it,drive the car as normal.it was more of a problem for bi-turbo cars.he said its totally your call if you want to replace it.
    so i am standing there wondering whether to replace it or not after what you guys had said about it which i didn't mention to him.so to be on the safe side i told him to go ahead & replace it which will be next sat.
    beachbuggy i wish i had read your post first about it being an easy sensor to replace before giving him the go-ahead to replace it as its not cheap fitted!
