Hi I'm new and need some help
John2708 Mar 22, 2013
  1. John2708
    John2708 New Member
    Hi I'm new to this forum but I have a few problems with my audi a3 the car doesn't idle properly this intermittent fault only happens some time it's normally from a cold start up I get the error code p1296 the things I have done to try and fix this problem are iv changed the temp sensor this hasn't helped iv changed this twice thinking a bought a faulty one what's the next move for repairing this fault my car is an audi a3 2001 1.8 turbo petrol cheers for any help John
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Idling issues I'd suspect vacuum hoses to be split or not attached properly. The normal suspects are the ones under the manifold.
    That code is to do with the cooling system but you've changed the temp sensor, have you changed the stat?
  3. John2708
    John2708 New Member
    No iv only changed the temp sensor
  4. <tuffty/>
    21,152
    3,834
    17704/P1296/004758 - Ross-Tech Wiki
    17704/P1296/004758 - Error in Mapped Cooling System
    Possible Symptoms
    Cold start issues
    Possible Causes
    Coolant Temperature Sensor (G62) faulty
    Coolant Thermostat faulty
    Possible Solutions
    Check Coolant Temperature Sensor (G62)
    Check Coolant Thermostat
    Special Notes
    Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
    Freeze Frame data stored at -40 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored at +140 °C is generally an indication of a faulty ECT or wiring.
    Freeze Frame data stored with in the 60-80 °C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
    Get the stat changed...
  5. Tim_Attard
    Tim_Attard Active Member
    473
    44
    i bet my left nut its ur stat change it only a few quid but pita job imo and should fix this i also had idiling issues when mine went so could be related
  6. John2708
    John2708 New Member
    Thanks for all the replies I have a few other problems but one at a time ill change the thermostat next see how it goes got to change a bearing tomorrow in the snow 😓
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Haha Join the SWAMC....Severe weather amateur mechanics club! Head is going on tomoz in the sub zeros...;)
  8. John2708
    John2708 New Member
    Just recently I'm always doing something to the a3 in the cold **** weather
