Hi can any help with a coding problem
Discussion in 'A3/S3/Sportback (8P Chassis)' started by Troubs12, Jan 19, 2012.
  1. Troubs12
    Troubs12 Member
    Oct 24, 2009
    92
    10
    hi guys long time no post i'm having some issuses with my rear lights the car thinks its got 2 fogs and 2 reverse lights since i coded tried coding for mirror tilt when reverse is selected then seen that you have to have memory seats installed for it. I completely didn't realise as in work (vw) the golfs don't require memory seats i know i know it was a school boy error but i didn't write down the coding for byte 3 and 4 (the ones i changed) and now everytime i start up i get the bulb out warning for both bulbs. I have tried looking at a golf coding in work thats the same as my car however when i put that coding in the dash lost power humm thats when i discovered they actually are different ha ha any help you guys could offer would be greatly appreciated i will say however i dont have vag com or vcds i have used a proper vag diag computer for all my coding changes (xenons, headlight washers etc) as it stands my coding for byte 3 is 00000110 and byte 4 is 1000000 hope to hear from you guys
    Many thanks
    Neil
